Steering Pump and Seals
- Replies 26
- Views 6.2k
Alexio Auditore 9 posts
dripley 4 posts
Tractorman 4 posts
IBMobile 2 posts
Hey guys, I'd figure i would give an update to the axle seal situation since I got it done. I'll just say it sucks, and hats off to those who can some how knock it out in an hour or two. I
It is likely that there is air still entrained in the system. Even after the initial bleeding of air, there is still lots of air trapped in various parts of the system - hoses, steering gear box, the
That looks like all the lines you'll need and an inline filter should be installed on the power steering box return line.
Hey guys. Sorry to write another thread, but I'm needing to get some things fixed and need a little help.
1st: powersteering pump.
So Genos garage has a new, not rebuilt borgeson steering pump for my truck. I believe its 800328. I've thought about just resealing mine, but there is more going on to it than I think a re-seal will do. Fluids smell burnt, its leaking, and it whines and groans prett bad, especially in the morning. 258k miles I'm sure it's about done.
They have the same pump on amazon, but the reviews arent pretty. So I'm not sure what to do here, I dont want to take a risk and buy a piece of crap.
While it's out, I'll be re-sealing the vacuum pump. Also, what is a good steering fluid to use in the new pump?
2nd: axel seal
So when I had my ball joints done, I was going to have my axel seal done too while he was at it. But he told me I have the wrong part. I made sure at napa it was the axel with the CAD, but when looking online at torque king .com, it doesnt look the same. I've included a pic of napas for some help clarifying too. Also, the torque king has the CAD seal too, NAPA didnt.
https://torqueking.com/product/4631/qk4631-cad-side-front-inner-axle-seal-tool-kit-1988-2001-dodge/
What are your guys thoughts?
My pump is leaking quite a bit just sitting over the weekend, I need to get it done soon.
Thanks for the continued help.
