First Power Upgrades
- Replies 7
- Views 3.1k
Popular Days
are you planning on upgrading your trans ( vb and tc at the very least)? If yes then keep reading, if no then keep it stock. I would honestly put 150's in not 100's if you plan on updat
tc and vb would be my recommendation, a good single disc will hold anything the hx35 do without overfueling. Get the adr and some 7 x .010's. I am not even sure you will need wir
You really need to drive a truck with a quad and good sized injectors. Egt's are not a result of injectors they are a result of bad tuning. I could put my foot to the floor with 7 x .012's towing m
Between selling stuff and saving, I have some extra fun money to spend on making my truck more powerful and hopefully more efficient. I see that DAP has Adrenaline units on sale, so am about to bite the bullet on one of those. I do have some questions as to what other items should be on the shopping list. Here is a list of what I do have or will have done in the next couple of weeks:
I plan to add a transmission temp gauge or dummy light(s), and have the Adrenaline monitor engine oil temp, but am open to suggestions on the matter. As some may have noticed in the Classifieds ads, I am looking for an HX35 turbo. I know 3" exhaust isn't popular, but unless overwhelmingly recommended to upgrade, I plan to keep that exhaust at least until I upgrade turbo. I see no reason to buy an exhaust for one type of turbo, then have to buy another downpipe because I need a 4" v-band downpipe for a Borg Warner S300G, etc.
My goal is to have some better performance while very occasionally pulling a 7k lb box/travel trailer on long trips, or heavier trailers much shorter distances (150 miles). I do not visit Death Valley nor do I plan to take said trailer over the Rocky Mountains. However, I do venture to places it's frequently over 100 or under 0 degrees and windy.
Is there a set of injectors that I should pick up with this Adrenalin, good for a guy who plans to soon have an HX35?
Is there a particular, really good starting-point tune for this type of setup that I should buy off of this site?
I would never think of putting 100 HP injectors in my truck until Me said it was a good approach, with a tuner that can shorten duration to keep smoke down. Will these big injectors cause problems when it's well into the negative temperatures, until the program kicks in at 140 or 170 engine coolant temp? Is that one reason to choose a tune WITHOUT the temperature limits?
So many questions! I hate to tag people, so I hope dieselautopower, Me78569, etc., happen across here and have some good advice for this very basic setup!
