Low Oil pressure light
- Replies 5
- Views 2.8k
98whitelightnin 3 posts
dripley 1 post
Dieselfuture 1 post
Sometimes my oe oil pressure gauge drops to zero and I get a ding with a light. This usually only happens when I’m at a lower idle situation while pulling forward and the idle gets low or reversing into a parking spot and idle gets low (idle is set at 815). It’s only happened a handful of times until one day last week when we had a 75 degree day and then it was dinging every few minutes during slow driving or idling. When I bought this truck, a little over a year ago, original owner told me about this and had a new oil switch in the door but I put a new mopar switch in it anyway. Mechanical oil gauge I have shows 23 psi or so while the gauge in the dash drops to zero. Do y’all think this could be a wire or just nature of the beast. Also, cold start oil pressure seems to come up slowly but I’ve never had a mechanical gauge on any of my other cummins. I’m using 15w40 and it’s not low.
