Ecm or something else?
- Replies 5
- Views 2.1k
Troy717 2 posts
Mopar1973Man 1 post
dripley 1 post
Great work! 1 post
Slightly new here but have looked around, yet still cant find an answer maybe yall could help. I have a 2000 24v that will run when doing the bule chip diesel hot wire to the vp44 test but wont run with the plug. Making me think Ecm. For some background the truck was originally a v10 model converted to diesel. The only part remaining from the gas version is the physical dash and dash harness(insturment cluster was swapped as well). The truck was throwing p1693 code when i had my cheap scanner hooked to it as well as the sending unit code. When i hooked up my nice snap on one it said there was no codes? Anyone have any ideas?
Edited by Troy717
