- Replies 16
- Views 10.8k
dripley 8 posts
shade tree fixer 7 posts
IBMobile 1 post
Never mind fooling with the unknown and make up your own wire harness; that will take the guess work out of what color wire goes to what. The article below may help you make a harness. @dripleyI
I have tried to find a wiring diagram somewhere for that harness. I even dug for the one I had but came up empty. The only things I can recognize in pictures is this. The fused wire is for 12v power a
I bought this, (see link) to make my "waste of money'' o'Reilly's in-tank pump work on with my block pump truck (to make the in tank pump)https://www.ebay.com/itm/DODGE-RAM-2500-3500-Fuel-Pump-Transfer-Conversion-Wiring-Harness-NEW-OEM-MOPAR/401565500005?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
and i don't understand how it's suppose to make my pump work, i need a diagram i haven't found anything that makes sense or is detailed
my truck is a 2001 bone stock 3500 C&C 24 valve nv 5600
https://www.oreillyauto.com/detail/b/precision-fuel-pumps-4602/fuel---emissions-16775/fuel-pumps-tanks-16472/fuel-pump-strainer-16843/fuel-pump-12322/83db8e3f0135/precision-fuel-pump-module-assembly/a30060/4614935/2001/dodge/ram-3500?q=fuel+pump&pos=0. This is the pump i have in the tank
