- Replies 6
- Views 1.5k
Bullet 2 posts
Cummins5.9 2 posts
IBMobile 1 post
Dieselfuture 1 post
Popular Days
Yeah... I have to wonder how he could’ve broke it. Could also be normal operation as you say, but the fact that it was never mentioned makes me wonder.. This was probably when the synchro
I agree 100%...I do everything myself too. I'm no mechanical expert but I can guarantee that no mechanical expert would care about the repair as much as I would. It's more satisfying to do it yourse
Good point.. I have had situations (on a telescopic forklift) where the exhaust bracket would continually crack from vibration or whatever, no matter how I tried repairing, replacing, or mitigating th
I was crawling around under the truck looking for problems and I noticed this cracked mount for the rear of the transmission. I was wondering if anyone else has seen this on their trucks. I searched but didn’t see any threads on it. What’s more, it looks like someone has tried to weld it previously, but it was never mentioned. My dad had the truck for a couple years but other than that I bought it new. The trans was out for a synchro replacement and shortly after that, the 5th gear nut fix. (Whole other story of clown work by a local mechanic).
Anyway, I ordered a new bracket and will replace, but just thought I’d post something on it. I was hearing a bit of a different kind of drone going on sometimes, seems more with the clutch disengaged than engaged, and this doesn’t seem like the culprit but in need of a replacement/fix nonetheless.
