- Replies 5
- Views 3k
Mopar1973Man 2 posts
Haggar 2 posts
dirtywhiteboy40219 1 post
Popular Days
DWB, Welcome to the forum! If you went from the stock 12 1/4" to 13" you increased the rotating mass of the clutch. (would be neat to know the weight differences to calculate
DWB, You may want to pop the tranny out and see what is going on. Mike (moparman) had made a good point on the pilot bearing... If that is damaged or dragging, similar issues
Hello from Germany....
I just installed a Valair single organic disc in my truck. The previous clutch went bad due to the input shaft seal leaking, y’all know the rest. I did replace the seal. I got the whole clutch kit from Valair, 13“ flywheel, pilot, throwout, etc. Even went the extra mile and got the ARP flywheel bolts.
The trans used to rake a little on the 2-3 shift if I was beating on it. Gotta show those pesky German VW drivers what the ‘ole dually can do from time to time.
After the clutch install, I can’t do a 4-3 downshift, at least like I used to. If I slow down to where I normally would shift to second, it will go into third. I never had any downshift issues before.??♂️ I don’t believe it has anything to do with the clutch. The only other thing that changed is the noise when lugging it. It used to make the rattle in third, now it rattles in fourth.
The pedal feels good, has a good, smooth engagement. Up shifts for all gears is just like before. First and reverse work perfectly. Fifth gear engagement is also great.
Y’all have any ideas why I can no longer do a 4-3 downshift?
thanks for any and all help!
