1999 Re-flash for a auto to manual trans swap
just recently swapped an auto for a nv4500. truck still runs, but occasionally will coast then surge ahead with a jolt. I have had it to the dealer and a private shop to have the ecm and pcm re-flashed, niether place could do it. Any ideas or will I have to buy a reman or junk yard computers?
  • Replies 4
  • Views 2.9k
You might try Cummins, Dodge dealer, or a junkyard. Also might try Ebay and maybe even give Jacob at DieselAutoPower a call.:thumbup2:
i don't know how the anti-stall works. i would think that if you can turn high idle and 3 cylinder idle on with a DRBIII tool, maybe you could turn the anti-stall off. if you could find a stealership that has a DRBIII and who is cool enough to try?
Ok the ECM is the controller of the anti-stall (Manual trans) but on a Automatic its not needed so both the PCM and ECM both need to be rteflashed to operate properly.
I know Smarty has done this with several HPCR ECM's, see if Bob can help you.
