Can any one give me the demisions for the trans mount plate on a nv4500 in a 2000 dodge 2500 4x4 mainly the thickness so I can build one but keep every thing at the proper height
  • Replies 5
  • Views 1.8k
I can't help unless you go by distance between back of valve cover and cowl. I think if you get that distance correct then engine angle and everything else should be ok. 4 and 1/2" from cover to metal behind rubber weather strip close to 4th valve cover bolt center of valve cover. Put a jack under tranny lift it to that distance, measure what you need for steel mount you're making allowing for some sag of mount.
Its the plate that bolts to the trans tail housing then the mount bolts to that. I mainly need to know what the thickness of space it has
