Truck Was Running Fine Suddenly Won't Start
I have an '01 Dodge diesel 3/4 ton that I rebuilt the engine on and it started right up after bleeding the fuel lines it started right up and ran fine. One of the batteries was dead and I replaced it tonight and went to start it up it just turned over like it wasn't getting any fuel. The overhead display read "CCD" and the engine light was on. The scanner pulled P0122 and P1698 codes. P0122 looks like throttle positon sensor and I can't find the P1698. Could replacing a battery killed the TPS sensor or was it just coincidental? I'd appreciate any assistance or insight anyone has on this.
  • Replies 6
  • Views 2.3k
The P1698 means it isn't getting anything out of the CCD. You might check all the connections that go to that battery if it was the drivers side with the hundred little red wires going to that positive terminal, making sure they are all making good contact. It also looks like you have a 10 amp fuse in the drivers side fuse block on the side of the dash that ties into it all. Might check that too.
Double check all you connectors under the hood. ECM and PCM then there is 3 connectors over the valve cover and check the plug in the PDC. Be careful not to strip the screw out in the PDC.
ALWAYS replace your truck batteries in pairs of the same date and manufacture. Not doing this will pretty much guarantee electrical gremlin problems. :nono:
Thanks for replying, it helped. When I changed the battery, a ground wire came out the terminal that I didn't notice and it fired right up. I replaced it and checked the ECM connections they were tight. If the PCM is on the passenger side of the firewall it's tight but I'm still getting the P1698 code and check engine light is still on. Again thanks for the help.
P1698 code is from the fact it not able to communicate between the ECM & PCM over the CCD Network...
Check your wiring sockets and connectors for being good and tight...
Posted Image
Checked all that I could find and were all tight. I disconnected the batteries and pulled the engine control fuses and cleared out the code. That cleared the CEL amd seemed fine until I found a water leak. Thanks for all the help.
