- Replies 11
- Views 6.2k
david7w5 6 posts
JOHNFAK 3 posts
Mopar1973Man 1 post
ISX 1 post
I have a 2001 dodge 2500 5.9 cummins 4x4 with an auto trans. When I start off in the morning I have to wait till the heat hand moves to leave the drive way. If i start off before that i have no power or speed. The truck does no smoke, use oil, or have any codes. It is not cold outside in the morning about 70 degrees f so i don't believe it needs pluged in. after it hits 190 degrees it runs strong. I am also fine all day as long as its driven ever so often. I did put a new lift pump on it and didn't help. Need help please...Thanks,
