At a loss, won’t start
- Replies 6
- Views 1.9k
Epr2x10 3 posts
Mopar1973Man 2 posts
dripley 1 post
What’s up guys? I’m at a loss and like most people, I need to try and get this figured out ASAP. Trucks a 2000 auto. About a month ago went to fire the truck up and check engine light was on and would just crank. Wouldn’t start, just crank. Felt like it was cranking as it (batteries didn’t seem low). I posted something on a different websites and was told to check the batteries and charge them. I did that and truck fired up and check engine light went off. Flew home today for work and went to start my truck at the airport and the same thing happened. Well I purchased a cheap $30 scanner to keep in the truck. It said there was a code being thrown but it wouldn’t tell me what the code was. I think it’s just because it’s a cheap scanner. Anyways I cleared whatever code was thrown and the light went off. Turned ignition off then back on and light came back on. Cleared it again and was able to start the truck. Truck ran fine for 10 seconds and shut off. Finally got it run and let it sit for about 15 mins. I got on the road. I live about 55 miles from the airport. I got 5 miles from home and the damn thing shut off while I was doing 70. Check engine light can on. Was running fine until that point. Pulled off the road, turned the truck off and took my key out of the ignition and the check engine light stayed on with the key out of the ignition and the Edge programmer I have (Older JWA w/ Legacy monitor) was still on. I disconnected the batteries. Reconnected them and fought the same issue. Crank but wouldn’t start. Gave it a few mins and finally got it started. Drive home with the check engine light on. I don’t even know where to start. Both batteries are fully charged since I drove 50 miles, I checked them when I got home with cables disconnected and they were both 13.1. Truck has the edge and a FASS 150. My initial thought was a fuel issue which is why it was cranking but wouldn’t start when I first had the issue but I charged the batteries separately and the issue went away until today. Any help would be greatly appreciated guys.
Chris Foster
