Nv 4500 bell housing torque specs.
Trying to find torque specs for nv4500 to bell housing and bell housing to adapter plate.
  • Replies 7
  • Views 12.6k
  • Thanks for taking the time to help .
    I normally just brake clean the spline shaft and leave the grease off the spline shaft. Yes it will splatter grease int the clutch. Throw-out bearings typically already have enough grease in the inner
  • Thanks for the grease info. Appreciate the help.
If you go to the download section, you will find the factory service manuals. I have found them to be an asset in answering questions such as torque specs.
Thank you so much for the help, Have a great day.
I checked my 4x4 Tech manual, here is what it has:
I would use very small amounts of grease inside the clutch housing. This is not a place for liberal amounts. If too much is used, it could end up on your clutch
I normally just brake clean the spline shaft and leave the grease off the spline shaft. Yes it will splatter grease int the clutch. Throw-out bearings typically already have enough grease in the inner collar. Just make sure to clean it up after installing. Even fuel leaks around 4, 5, 6 can drip fuel into the clutch area.
