Compound turbo oil drain(s)
I have a homemade compound setup that has supply lines but does not have return lines as of yet. I was planning on using another oil drain of some sort. Either factory or aftermarket that pops into rear freeze plug port. But, what size is the hose for the factory turbo drain? I’m asking cause I don’t have any extra return hose laying around to measure “ID” So I can just order a bulk piece and cut to length. 5/8, 3/4, 7/8?
Edited by Waydin_Stewart
  • Replies 3
  • Views 2k
I believe the ID is 3/4. I have 5/8ths hose that will just barely fit in the stock one on the block. As far as where to put it, I can't help there.
I’ve seen a few people make AN mines and put a Y fitting to use the single factory drain. Haven’t seen anything bad on it.
So I haven’t read about just using 1 drain hole. I am going to try and find a scrap piece of factory return line to get a size so I can order 3 feet or 4 to make my own return lines. If I can find the core t drain fitting for the rear freeze plug hole I will try to use it. It’s going to be a while encore I start putting them on. Just wanted to get everything set for when I install them
