Abs question
 I touched on this a little in another thread a while back. Finally getting to it.
 My abs light flashes constantly. The red brake light on the dash is not on, only the flashing abs light.
 I have read through the abs article and it refers to the abs/brake light both being on. So that didn't really give me a definite answer to my problem
Abs light flashing, no parking brake light on and the speedo is working fine, cruise control works, brake lights come on when brakes applied as they should and 4wd light comes on and engages as it should. I did replace one front wheel speed sensor yesterday, planning on doing the other side either today or tomorrow but I feel it may not be the issue.
 Anyone else ever run into this?
 Any advise would be appreciated. The light is just annoying.
  • Replies 24
  • Views 5.5k
  • Doubletrouble
    Doubletrouble
    ***Final Update***  I had my buddy hook up to it again with his snap-on scanner. He found that the rear axle setting was on 9.5", the options were 9.5 and Dana. He set that to Dana since the truc
  • Royal Squire
    Royal Squire
    If you know someone with a snap on scanner I believe it will read abs codes
  • Dieselfuture
    Dieselfuture
    Maybe the module going bad, scanner would be nice to know for sure.
I may need at tutorial on how to do a decent signature. I can't seem to figure it out
I'd like to have a pic in it like mike, couldn't figure it out though
Actually the signature part was suppose to be given up for a link to your garage. As you'll see above (or below this post) my signature is a link to my 4 pages of mod in the garage.
Reason why is 77% of the traffic here is mobile device and when you allow long signature they might have to pan down 2 screen loads worth of long signature to get to the next post. Not fair to mobile users. Being I see the same thing on my own phone.
 Yeah, you've explained that to me before. I just didn't understand how to set that up. I tried but failed 😔. Lol
 I'm not to computer savvy, I get by but some things still elude me.
