No cruise control after engine swap 2002 into 1999
- Replies 8
- Views 2.1k
dripley 3 posts
IBMobile 2 posts
Gregjr 2 posts
Mopar1973Man 1 post
Ok, here is my issue, I recently wrecked my 2002 Ram 2500 H.O. 6 speed and totaled it out. It only has 97,000 miles so I purchased a 1999 3500 with Cummins and an auto tranny to put my motor and transmission in. I have completed the engine and transmission swap and all is well....almost. The cruise will no longer work, the light won’t even come on in the dash. It worked on both trucks before the swap.
Here’s another known problem, the 1999 truck had the vacuum actuator under the driver’s side battery for the cc and the 2002 cruise control is all electronic controlled. I used the pcm and ecm from the 2002 so I didn’t hook the vacuum actuator up as the 2002 didn’t use it. Any suggestions would be great.
Thanks,
