Indoor Quadzilla Monitor
Kind of nice to be inside the house and monitor the truck as it warms up a bit and I can finish a bit of web work before I leave for work... I just had to share this I don't know if most of you know this trick.
Yuo can see the truck is just outside the window. My cellphone is on my desktop.
  • Replies 7
  • Views 2.4k
    WiFi should be stronger signal. At least my WiFi here reaches across the yard nearly to the fence. But alas I'm Android and use bluetooth...  Merry Christmas... ive gotta get back to trans service
    The Bluetooth for me is about 20 to 30 feet distance. I've also cut the bluetooth head lead and extended into the cab this gave even more distance being there is glass windows to transmit out of versi
  • As soon as I hear my exhaust break kick off I know she’s pretty warmed up. I think it kicks off at 150-160 degrees.  I don’t think my WiFi Quadzilla would reach into the house. I’ll have to check it o
That’s awesome!
The Bluetooth for me is about 20 to 30 feet distance. I've also cut the bluetooth head lead and extended into the cab this gave even more distance being there is glass windows to transmit out of version trying to transmit through the hood metal. Bluetooth head is just under my my shift tower plastics.
Yeah it even snowing today and its cold out too.
I have my quad sitting on the bench.  Had to change my exhaust manifold and getting that part took many weeks.  Also the turbo took forever to get with all the right parts on it.  That Quad will go in soon.  Thanks for sharing this trick.  And I may relocate that unit as well.  Seems like a good idea somehow.  I have a little shelf in my cab at the top of the windshield for my   I can probably get it up there for the best range.
As soon as I hear my exhaust break kick off I know she’s pretty warmed up. I think it kicks off at 150-160 degrees.  I don’t think my WiFi Quadzilla would reach into the house. I’ll have to check it out.
Merry Christmas... ive gotta get back to trans service...
Merry Christmas! It doesn’t run through the house WiFi. The Quadzilla puts out its own WiFi signal. I’ll go out now and check it out. Only works from about 10 feet away.
Edited by Threadzy
That's magical!!!!
