Adrenaline High Idle Not Working
- Replies 16
- Views 2.6k
LorenS 6 posts
dieseldon 5 posts
Mopar1973Man 4 posts
Me78569 1 post
Before I call Quadzilla for support, I thought I'd ask for suggestions here.
I recently noticed that my Quadzilla high idle won't start anymore. I have checked several times that it is on and the elapsed time is set right now to 60 seconds. I have tried other tunes and it doesn't work with any of them. I have deleted and reloaded tunes, that didn't help. I checked that my Vehicle Selection is correct, V2 Dodge 98-2002 version 2.7, NOT the 4k.
This summer a rodent chewed a little hole in my iQuad box. I have since used a VERY small piece of that rubberized/foil backed tape to seal the hole.
I have not had to jumpstart the truck. The only time a battery charger was on it was a little 40A model, but of course was connected to the driver's side battery.
Everything else seems to work right.
Any ideas? Should I again backup my tunes and do the "Default Profile" and "reset the device to the defaults"?
