Need help with codes and "no bus" HELP PLEASE!!
- Replies 13
- Views 10.1k
rooster4473 5 posts
Mopar1973Man 4 posts
guesswho512 1 post
98whitelightnin 1 post
This truck has been at a garage for 4 months, its been torn apart, scattered and ignored, you get the idea. The garage said they couldn't get the codes and they didnt know what was wrong with it, I finally got it home and kinda got it togeather. When I took it to the carage it would idle, but not much more, now it wont even start...... Last night I finally got the codes off my truck, there are 12 of them as follows: P0121- tps voltage does not agree with map P0122- throttle pos sens volt low P0243- turbo boost limit exceeded P0236- map sensor too high too long P0351- fuel inj pump fuel valve feedback circ P0252- fuel inj pump fuel valve stuck P0253- fuel inj pump fuel valve open circ P0380- glow plug circuit perf P0382- intake air heater relay no2 ctrl circ P1688- Internal fuel inj pump cont failure P1689- no comm between ecm and inj pump mod P1698- no ccd/j1850 msg from tcm/pcm ( I got the DTC codes from edgeproducts.com) Id hazzad a guess that my VP44 is toast, but today I changed the battery cuz the one was dead, and I figured I'd clear the codes and read them again, just for fun....Any way my OBD2 now says "Link Error" and my odometer is saying "no bus" If I turn the key on just enought for the trouble lights to come on they will all come on, then they all go out, then the odometer flashes 4X and the odometer reads "no bus" then the check engine light comes on. I checked that one big plug in the fuse box under the hood on the drivers side and the bolt in it wont tighten down all the way, almost like its stipped out, and it has a little bit of play in the plug, but not a ton. I also found what I think is a ground wire, its black and comes kinda off of the lip of the cowl more towards the passanger side of the truck, but im not sure where the other end should attach, it looks like it should go to the one bolt on the pcm but im not sure. The lift pump cycles, im getting fuel to the injector pump and up to the injectors, the motor will turn over good but, but hasnt started. Any help at all, any suggestions, esp how to get rid of the "no bus" code would be really appreciated, at least with the no bus code gone I could read the OBD codes.
