Steering near impossible when slow or stopped - 2003 2500 5.9L Cummins
- Replies 13
- Views 12.5k
Rogan 6 posts
Mopar1973Man 5 posts
Dieselfuture 2 posts
Could have entrapped air in system being it's leaking and he's probably adding fluid. You can always try this.
If the fluid is foamy after running your too low and do have air trapped in the system. You could start it up and purge it out then you have to shut down till the foam goes away typically about 30 min
Best to jack up the axle in the front so the tires are off the ground. Now if the reservoir is full the go from lock to lock WITHOUT the engine running. The movement of the piston in the steering box
Went out to a friend's house last weekend to look at his truck for him. a month or so ago, I put a new steering stab (oem) and sway bar end-links on. shortly after, he started complaining about super hard steering when slow, or backing up...
So I went out there and disconnected the stabilizer, for SnGs..
No change.
Power steering pump is leaking, but had plenty of fluid in it.
Hydra brakes work fine. Just cannot hardly turn it sitting still.. I don't wanna throw parts at it (pump or steer gear) without knowing pretty sure what is the issue. Any thoughts on this are greatly appreciated..
Pump doesn't whine/groan/nothing..
