2006 Dodge Ram - Installing injectors
Well...
I finally got back from DAP with the injectors and started the next day stuffing the +50 HP injectors in to the 2006 Dodge which has been named "Thor". I will say after getting all the work done and being able to drive it for the first time in nearly 3 YEARS. Yup the previous owner left it out in a field for over 2 years with a wiped out throw-out bearing. Now with the injectors and new clutch it runs pretty good. I still got a wastegate solenoid to get or fix. The best for last... I did custom license plates on the truck... MPR73MN
  • Replies 5
  • Views 1.8k
    So... here you go. All put together and running. Just gotta debug a few minor things.
Would have thought you'd get that for your original truck, maybe something like powrwgn wood be cool too, that's what I wanted but all versions of it was taken here so I got stuck with
We as in @Jthor and myself wanted TH0R for a plate but it was taken. This truck is going to be our shop truck. I'm going to put tool boxes down the bed sides. Load it up and get to work. Takes time, money, and lots of effort to get it together. I've already been talking to local shops and working trades. So if they don't want to deal with diesels hook me up. I'll in return send my gasser work.
I see even 3rd gen drivers seats can only take so much arse rubbing too.
