- Replies 3
- Views 1.1k
Mopar1973Man 1 post
dripley 1 post
Doug Dear 1 post
I have had the dead pedal or atleast partal dead pedal. It will run along fine then dead pedal on me so, I turn the key on/off and it acts like it didnt happen. Bought a new apps sensor. Didnt fix it. Low voltage about 2 or so. Did the W/t mod. Hoping it was a ground. I had metioned I had a code Po 2016 injection pump timing. It is a brand new pump 150 miles so, I said no way but I was told to use some Atf. I finished the W-t mod replaced the fuel filter 1/3 of the atf with the filter rest in the tank. Ran it for 10 mins drove it 10 miles it dead pedaled only on time. Much better it was doing it everymile. Today it still did it twice. Put on the scan tool and got the po2016. So is it the pump after all? Anything else I can do. I am installing a fuel pressure gauge this week.
