Daniel Stern Lighting Sport Headlight Harness
- Replies 16
- Views 8.4k
Mopar1973Man 5 posts
BRI7070 4 posts
sleezy 4 posts
Tractorman 2 posts
Hello All,I have a 2001 Dodge Ram 2500 4X4 CDT Auto, and I did the sport headlight conversion a while ago and I recently bought the wiring harness from Daniel Stern Lighting. My initial impressions the harness uses very good components and heavy gauge wire. My truck was an export to Canada and I do have the DRL and I did the DLR mod as instructed by Daniel stern.
However I do have two problems that I am tiring to resolve.
1. When I hook up the harness the drivers low beam is on all the time with the key on or off. When I turn on the headlights the low beam works only the drivers side and the high beam works as it should.
2. My fog light relay in the PDC is rapidly cycling. I do not have fog lights.
I have reached out to Daniel and he was talking with his harness builder to determine what the issue is. Daniel has responded with a few questions and I have promptly replied to his questions.
I have returned the truck to stock including the DLR mod and my headlights work as they did before. I did notice when I un-did the mod on the DLR side that is when the cycling of the fog light relay happens.
It has been 10 days and 4 emails since the last email Daniel has responded and my last email requested help to resolve the issue or provide a return for the money spent as I do not need an expensive paper weight.
Has anybody had similar issues with the harness and may have an answer to get the harness working? As i said earlier the harness is of good quality and I would like to use it.
Any help is greatly appreciated.
TIA,
Brian
