P1689 Very hard to start after VP44 replacement and ECM reprogram
- Replies 13
- Views 2.8k
skiracer0112 6 posts
Mopar1973Man 4 posts
Haggar 2 posts
Silverwolf2691 1 post
Hope this can get you started. Follow the instructions to the letter and it should get you some answers. I think that 14 ohms to ground could be playing a part in this.
Good morning, I bought what I thought was a good deal of a truck during the pandemic, a 1998.5 3500 auto dually. This forum has been very helpful thus far but I feel like I have hit a bit of a wall and was wondering if anyone had any suggestions before I go down too many rabbit holes.
Currently my truck is showing a P1698 code, which can be cleared but immediately returns. It s very hard to start but will get going, rev and not throw the code when in park or neutral. As soon as it is in gear and a load is applied the code pops and the engine derates.
After installing the new vp44 it was running and staring very well. P1689 started suddenly on my way home one day about 300 miles after installing the rebuilt vp44 and has progressively gotten worse.
Repairs before P1689 issues started
Rebuilt VP44 from thoroughbred diesel last summer, tested this spring with a breakout box
Edge tuner removed
replaced grid heater relay, can’t remember code but bad circuit code popped
Repairs since P1689 started
Had ECM rebuilt and is installed with no change
Tested continuity between vp44 and ecm, all good but 14 ohms on ground
Cleaned all grounds on top of the motor
Thank you in advance!
