Looking for Staff Members
Hope this is ok to put here.
I wanted to put the history and semi build up of my truck so far for both record and might be able to help others some how.
So, I have been a dodge fan for years, partly because my father works at a dodge dealership and because the only non dodge product we have ever had in the family was a mid 2000s Subaru Legacy. My first time driving anything was when I was like 3-6 years old, my father let me steer his Jeep Grand Wagoneer down the road. We actually still have that jeep but it has fallen into disrepair because of reasons. I personally have had a 1999 Jeep Cherokee (on loan from the parents), 2001 Dodge Ram 1500 (was my first vehicle I could call my own, sold a few years ago), 2001 Dodge Ram 2500 (nearly my dream truck, needed to be a sport to be my 100% dream truck), currently also own a 2019 Ram 2500 (needed because I chose to start sled pulling with the 2001 Cummins and I needed a second vehicle). Also have a 2016 Yamaha Stryker for a motorcycle.
So this was the morning after it was dropped off to me in 2015:20150201_104612.jpg.3ab0d566469b31ce9d0a6d55396af535.jpg
I actually bought the truck off of a classmate of mine so that was a fun surprise.
And so began my foray into the world of diesels.
Unfortunately, previous owner didn't take good care of the truck. No power steering fluid, and it was really low on oil, like half of the required amount drained out my first oil change, and the steering was really all over the place. Also, the exhaust was cut off right at the end of the cab, and the mounting rod that attaches to the tranny had broken off allowing the exhaust to just rattle against the tranny crossmember. So I swapped it to a set of MBRP cool duals.              20150404_110944.jpg.0ad203d8077209edb87158c3116853a1.jpgOut with the old
In with the new.
Few months later gave the truck a bath.
Also after, digging through my photos, I don't take a lot of photos of the projects I've done. Or I cant find them.
First big issue was that when I went and got new tires for the truck, the place that was doing the alignment broke my nv5600. Unfortunately, said place is a regional chain in the northeast and gave me $500 as compensation after the company that rebuilt the tranny said that they had seen this kind of failure quite often. they forced the shifter into a place it wasn't supposed to be and separated the circular thing from the actual shift rails. Top right corner is where it was disconnected.
So i used this time to get a fresh rebuilt tranny, rebuilt driveshafts, a Valair dual disk clutch and new shift tower.
  • Replies 122
  • Views 16k
  • Silverwolf2691
    Silverwolf2691
    parts finally came and the next week is going to be something resembling warm (40s).. turbo photo was blurry that why its not posted..      @dieselautopower love the boxes lol
  • dieselautopower
    dieselautopower
    Powder coating is better.  It would not affect the warranty unless you assembled it wrong or the wheel was damaged when the cover was off.
  • Silverwolf2691
    Silverwolf2691
    Took the turbo apart this past Sunday to check on the wastegate pucks.. they were off just enough to rattle when poked with a screw driver.. 2-3 turns shortened up the rod enough to seat them..  also
Oh I been working with moparman alot on this already, but having a difficult time finding a good timing setting then all the OTHER settings, cruise timing, max load, canbus fueling, etc.......
Egts are through the roof, no black smoke (not needed - just for testing purposes and tuning), I have went through 5-6 sets of injectors with dap, new vp44 (unfortunately not the dragon flow anymore) new lines and cross over tubes. Add everything else in sig+
Might still have a injector knock again, checked compression (amazing numbers) checked and set valve lash 3-4 times with in the last 2 months. Has white ish smoke on start up
Long long  story with everything and getting to this point but this is where I am now.
What kind of engine build did you do? You had photos of the engine on a stand in another thread..
It might be your turbo for the EGTs.. the 71 turbine in the super b was known as a low drive pressure wheel so it flowed a lot but didnt spool well. The newer 73.4 supposedly spools much better. If there was a way to get a 12cm housing on the 71 that might help too. As for the white smoke not sure on that..
I basically just re-sealed everything minus the head. It's a stock engine with cam/springs plus turbo and fuel etc.
I'm gonna do a complete build process thread at some point with all that I have done to it, maybe slide show too...
Got my exhaust all back together this weekend.
Found a 409 stainless  4" x 60" piece of pipe on Amazon for about $75. Everything seems to just be 48" max length or all the way to like 7.5 feet. I'm glad I found it so that I didn't have to add another clamp and 13-18? inches of pipe.
Now just have to get my injectors in and swap a cylinder head. Need to get my little green truck on the road, and sell my 2019 first though.. Green truck needs to be insured and registered but is mostly road worthy. Needs tires, a front end rebuild, a catalytic converter, and muffler to be a decent daily driver. Hoping for this week to be registered but we'll see.
New thing i need to diagnose. After getting my down pipe in, my Quadzilla is reading solid 300* tranny temps (engine oil temp for me) even cold..
Havent looked for anything yet.. didnt have a chance yet today.
Took my dog out for the night and took a look at the sending unit. Turns out the hearter core return pipe got tweaked onto the top of the sending unit when we were putting the down pipe on yesterday. So i tweaked it back away from it. See how it is in the morning.
Look for the ring terminal lead out of the Quadzilla. Tape it up so it not touching ground.
Priorities shifted to my 1500 recently so a bit of a pause for a bit. Need to un-basket case it to get it reliable for daily driving. Needs the whole front end redone along with tires and brakes all around. Tune up as well. Need to get a part swapped in the bell housing too..
That's what I get for trading a Milwaukee m18 impact and some of my time with my brother.
Yeah I know the feeling I just dropped $400 on a new windshield in the Grand Caravan. Also got my water leak fix being the body was rusted through at the top of the windshield. Two for one fix deal...Ugh. Being gasoline is dollar plus  cheaper than diesel so the mini van is getting more attention for the moment.
Finally got my 35s on, that i got on Christmas. Its different for sure but not overly so. Have to fix my bumper and remove my mudflaps for sure. Probably have to heat up my fender liners as well. Other option is a leveling kit of some sort.
Retuning is gonna be fun.
Remember if you do a leveling kit make sure to do it right. Change out the control arms for adjustable so you get caster angles correct and adjustable track bar to get the thrust angle correct.
Have adjustable track bar and longer Carli control arms (non adjustable though).. i need to go though my front end and see whats up with it.. its both tight and loose, as weird as that sounds. Just kinda feels like the front end is floating but it goes where i want it to with little hesitation..
  • 3 weeks later...
So im still running my 50s right now but i think there is something wrong with them. Ever since i put them in, I've had low end smoke issues.. and yesterday i finally followed the tuning guide and figured out that to be fully smokeless, i need to be down at 76%. If i have it at stock they let out a decent cloud of black. Even taking off easy..
The 50s are from DAP from 2018? They dont have many miles on them maybe 20-30k? I'm a bit at a loss as to the reasoning why..
Low pop pressure?
Spray pattern?
Bad product? (Hope not)
I would consider pulling those injectors and having them pop tested. +50HP injectors shouldn't really smoke at all, remember as pop pressure falls the flow rate will increase, timing is advanced, fuel spray has bigger droplets. I'm smoke free with +150HP injectors but popped at 320 bar, even currently I'm back down to near 310 bar just judging idle engine load. So new it idled at 13 to 14%, then now it idles at 6 to 7%.
Yes it's possible to lose 10 bar worth of pop pressure in the first 20k to 30k miles, I've seen it happen to a few members. Doesn't matter who builds the injectors. Just remember the lower limit is 293 bar according to the Dodge FSM.
Bigger turbo will slow the spool.  76% seems a little low for 50HP mid 80's would be more typical.
"smoke" is also subjective.  To go smokeless you may need to tune lower like you have.
If you want to send the injectors in to get inspected and pop tested we offer that service at a discount for our customers with our injectors.  Please call in.  Turn around time is typically less than 2 days for repairs.
Smoke to me leaving a lingering cloud on an easy take off I guess.. Never had to put words to it before. 76% is low on power but as smoke free as factory stock so far..
Injectors were put in August of 2017 and 25k miles ago.
Engine load has stayed the same since I had the quadzilla but I got that in June of 2020. Always been 6-9% at warm idle. Engine load drop probably happened while I still had the edge ez..
Thank you for the info.  Since you bought the injectors through us If you want us to go through them and reset pop off pressures and check for any nozzles that may not be popping crisply then it is $110.  That includes new washers and return shipping.
Not sure because if i dont turn them in for cores for the 225s (over 30 days.. dont know if its still ok to turn them in) they become spares..
Would it be possible to get them either enlarged or re nozzle'd with the understanding of extra cost added on if it is possible?
I'm also fighting a slow map sensor.. there's 3-5 psi on my isspros before the quad registers 1 psi.. It actually gets more accurate/lower pressure difference with more pressure.. is this something to test to see if its bad or is this a luck of the pick for parts and i need a new map sensor?
Using the Quadzilla for a boost gauge isn't a really good idea. Even mine is skewed but on the upper end more so than the starting edge. At 47 PSI on the ISSPro it was reporting 69 PSI in the logs. I can see why you want to get better on the lower end because it impact when your power comes on. Personally it good to use the gauge to check for MAP sensor performance be be aware I doubt you'll get it accurate over the entire span. Yeah I would look at getting a new MAP sensor. I not going to suggest Cummins OE sensor either. More I keep digging the more I find that Cummins actually doesn't produce. (Head Gaskets, Thermostats, etc.) but you pay higher price for junk parts.
