2008 MC 6.7 - Derate Issues
- Replies 9
- Views 4.5k
Mopar1973Man 3 posts
AH64ID 3 posts
Rogan 3 posts
Popular Days
@Rogan got you covered.
It sounds like an emissions/DPF derate. I would check all the disconnected plugs for corrosion or something else that might be causing a short. I see AlfaOBD shows low fuel pressure derat
High pressure pop off isn't all that uncommon and why FPRV delete's are not recommended. The injectors stop injecting much faster than the CP3 reacts to huge changes in load, i.e. WOT to 0% throttle.
160k miles on it. G56, RaceMe Tuner, deleted. Truck has newish Bosch injectors (OE), 5" exhaust, stock airbox, deleted egr/dpf, etc.
Recently, it's developed this issue of falling on it's face when hooked up to something (dump trailer, hay wagon, etc). It does it empty, or not.
I have Alfa OBD, and hooked up, and I see the following:
No codes that I find. When it falls on it's face, it dings and I get the 'see dealer now' message.. After about 5 secs, it picks up where it left off and drives normal.. then it may/may not do it again..
Fuel filter changed, newish in-tank pump..
crap, wrong section of forum..
