01 Dodge Cummins tach issue
- Replies 9
- Views 5.2k
Brandon39 4 posts
Silverwolf2691 3 posts
Mopar1973Man 1 post
dripley 1 post
Popular Days
I figured out my instrument cluster is bad. I swapped in a different one and my rpms were spot on
Hi this is my first time posting. I got a 01 quadcab cummins from my girlfriends grandfather that passed away . It has the h.o. motor and a 6 speed standard. Back in 08 he put a new motor in and had problems with the tach ever since. Now that i have the truck i had it idling with my scanner plugged in and the tach says its idling at 500 rpm. The scanner says 800 rpms. When the scanner is reading 3000 rpms the tach says 2000 rpms. Other than that it runs good . Any help or ideas would be appreciated. Also my redline on my tach is at 3000 rpm which is odd because every other cluster ive seen is around 3300-3400
