P1694 and P1698, Diag help
Hey,
ive got a 2001.5 2500, 6-speed truck.
intermittently my tach/oil press/water temp gauges will stop working. Typically when this happens my engine also has a quick “kick” to it like it shuts off and jumps right back on. I never get the “nobus” message on my cluster.
if I check my codes I have p1693, p1694, p1698. Also randomly a p0501 code and ABS light.
I replaced my ECM for this issue 1-2 years ago but it didn’t change anything, but I used a reman one so not sure if it’s quality. The issue never went away though.
was hoping someone could help guide me through what wiring to check, or really just help me determine what my issue is.
I believe I’ve monitored my RPM with my zedge before and when my tach is dead the RPM still works on there as does Oil Pressure, but the Water Temp just stays in one spot until the gauge comes back to life on the dash.
any help is very appreciated, oh and I have no access to a DRB3
  • Replies 51
  • Views 12.1k
  • All right i will add it to my todo list while diagnosing this.
  • Great work!
    Great work!
    Because the bus is active and talking those voltages fluctuate. During a very long idle state which is very unlikely the voltages will settle.
  • Lol I threw an ECM at it once hahaha but I tested before that too, just not as thoroughly. Think I just got a badly rebuilt ecm. On the bright side I now know a lot of the wiring. I’ll definitely keep
So I’ve gone through the diagnostic list to find that it’s saying for both of these codes I’m basically looking for an issue on the CCD bus. So I’m checking Pin 40 and 41 from ECM to DLC for open or high resistance, pin 30 and 28 at PCM C3 connector to DLC for open or high resistance, Pin 31 at PCM C1 for resistance to ground, and pin 30 at ECM for resistance to ground.
is this all I need to be looking at? Only the CCD circuit for both these modules?
On my way to work this morning I decided to double check. When my tach dies I can still get my RPMs from my edge CTS. Not sure what that means but it seems weird that the RPM is making it to the DLC but not my cluster somehow.
Yes your problem is CCD network issues. Another way is to turn the key on and the probe the CCD pins on  the OBDII plug under the dash it should show 2.51 and 2.49 when the computers stop talking. That is normal Bias Voltage.
Yea I plan on checking that voltage at the DLC after work. If I don’t see that voltage what would the next step be? Unplug modules on the CCD bus until it goes back to normal? Or just continue with the resistance checking from DLC to PCM and ECM pins?
do you think it’s going to be a wiring issue rather than a module? Any chance it’s my cluster?
Normal you can remove different modules that could affect the voltage.
Modules that can't be removed...
  • PCM - This is source of the CCD network.
  • ECM - This is the secondary computer.
  • Gauge Cluster - This creates the bias voltage.
All other modules are optional and can be removed.
  • Central timer
  • Radio (Stock OEM)
  • Air Bag Module
  • ABS Module
  • Overhead Trip Computer
Causes of failures and errors.
  • Bus Shorted to Battery
  • Bus Shorted to 5 Volts
  • Bus Shorted to Ground
  • Bus (+) Shorted to Bus (–)
  • Bus (–) and Bus (+) Open
  • Bus (+) Open
  • Bus (–) Open
  • No Bus Bias
  • Bus Bias Level Too High
  • Bus Bias Level Too Low
  • No Bus Termination
  • Not Receiving Bus Messages Correctly
Remove a module and check the voltage on the bus to see if it returns. If not you didn't find it.
Alright hopefully get a chance to go thru it a bit today, humidity is like 100% tho so we’ll see if I feel like working in this stuff
really hope I can get this solved, I’ll feel much better about finally doing the mods I want to do if I know everything works first
When I was playing around with a spare ecm I had same thing happen, lost tach on the dash but was still seeing it on my quad. I was told that the pcm needs fixing but I knew that I didn't have this problem before I swapped the ECM so I put my original one back in and no more problems.
I don't know if I had lose connection on ecm or something is wrong with it inside, it ran perfectly fine other then loosing tach signal.
I would do the WT mod and check alternator for AC noise, check all other grounds you can think of.
All these talks about chasing wires and very rare it's any of it (unless it's one of the splices that WT mod covers), most of the time it's grounds and ac noise, and sometimes failed ecms because of bad grounds and ac noise that been slowly burning up the modules. This is my opinion, it's still worth checking what is suggested by others, never know. WT mod is needed on our trucks and easy to do, same with ac noise it needs to be checked once in a while. There are other ground splices that need attention, but WT covers the important ones that cause most issues.
Yea wish I had a spare ecm laying around but already threw $1000 at this ecm which didn’t change anything, and I’m not sure if I’d need to program a used one as the info on that topic seems all over the place online.
How would I test my alternators AC output?
the ground wire mod, if needed I should be able to detect when testing the ECM ground. Worst case I’ll do the ground portion of it, not really trying to mess with moving my alternator wire and adding on a new circuit breaker etc.
Found moparmans video for testing AC noise from alternator, I’ll test that later as well
Quality DVM like Fluke or similar that can measure small AC voltages. Red probe to the alternator charge stud and the black to clean block metal is best or the negative on the passenger battery.
You really need to. The alternator lead is paired right next to the ECM ground and VP44 ground so when AC noise is created the noise jumps right into the ground leads and pollutes the ground signals to the ECM. This is a required mod. The alternator charge lead is move solely to the passenger battery and the ECM ground are to the gear case and the driver side battery. No longer an issue after the mod. Dropped me from 55-60 mV AC to mere 9-11 mV AC after I was done which is acceptable.
Where would I put the 150A circuit breaker? Just between the new alternator to passenger battery wire?
haven’t had a chance to check things out, tweaked my back a bit and combined with this 94 deg 100% humidity weather I can’t convince myself to work on the truck atm.
but I’m compiling all this stuff to check/do once the weather breaks
When I did mine I pull the entire charge lead out and re-routed to the passenger battery. The circuit breaker I put on the firewall side of the battery tray. The entire cable was completely re-used. The ground side I salvage the plug on the passenger side and made a new jumper from the driver side battery to the gear case.
Ok first chance to look at stuff. For starts I’m using a Fluke 88V which I know is balls on accurate, I regularly use it to trace amperage draws and such at work (mechanic)
measure from Alternator stud to negative terminal (on both batteries) .030-.040 AC voltage. Watching dashboard as tach died and came back there seems to be no correlation towards higher AC turning tach off. While monitoring the AC voltage though the tach issue seemed to occur often but that could be random
2nd Test- my tach is dead during this test, Key On Engine off. Ground to OBD2 Pin 3 - 2.49V, Ground to OBD Pin 11 - 2.46V
checking resistance across Pin 3 and 11 of OBD is showing 60.6 ohms, with minor fluctuations (key off, batteries connected). Biggest fluctuation was dropping to 52 ohm very fast before going to 60 again
think this means the network is good voltage-wise. Resistance I’m not sure of. I’m open to opinions tho.
3rd Test - With tach dead perform cluster test, everything functions properly. All needles work. Only codes showing on cluster are P1694 and P1693, p1698 only shows on my Edge unit I guess
4th Test - Pin 30 ECM to Drivers Battery Ground - 0.5ohms, to Pass Battery - 0.4 ohms
5th Test - ECM Pin 40 to OBD Pin 11 - 0.6 ohm
ECM Pin 40 to OBD Pin 3 - 60.4 ohm drops to as low as 52ohm randomly but not often
ECM Pin 41 to OBD Pin 3 - 0.9 ohm (not a fan of this) kept monitoring it settled at 0.6-0.7 ohm by itself but definitely keeping this on my list
Ecm Pin 41 to OBD Pin 11 - 60.6 ohm (didn’t sit and watch it long)
going to end testing there for tonight. I’m a little suspect of ECM Pin 41s resistance to OBD Pin 3, also not a fan of the CCD resistance randomly dropping to 52 ohms I may need to test that more
Edited by teknic
Check and clean C3 connector on PCM and the two connectors near center of firewall by vacuum tee. Also two splices above AC accumulator in the harness. Have a helper watch dash while flexing and wiggling connectors and wiring.
I did pull and separate the 2 connectors by the vacuum tee, didn’t see anything abnormal on them and so put them back together. I’m going to be moving to testing the PCM connector today, thanks for the splice info I’ll be sure to check those out also. I’ll put together another list of things soon.
im just trying to document all these things because it seems like a common issue that has pretty limited detail info on it out on the web. So hopefully I can fix my issue and help someone else down the line one day.
Ok now to PCM connector
tach dead, issue present. Pulled all 3 PCM Connectors, visibly they have no signs of damage, all pins look to be fully seat to the connector. All this is with Key Off, Battery Connected.
6th Test - PCM C3 Pin 28 to OBD Pin 3 - 119.7 ohms, didn’t fluctuate at all
PCM C3 Pin 28 to OBD Pin 11 - 0.8 ohms
PCM C3 Pin 30 to OBD Pin 3 - 0.5 to 0.6 ohms
PCM C3 Pin 30 to OBD Pin 11 - 119.9 random spikes down to 102 ohm
7th Test - PCM C1 Pin 31 to Ground - 0.2 ohm
I also started pulling the harness wrap apart starting at PCM, only found the violet wires splice and that was over the valve cover, the white wire splice must be closer to the 2 connectors by the vacuum line. Still going over stuff at the moment.
After doing all this and then reconnecting the dash came back to life, gonna let it idle and see if it reoccurs or maybe the area I was testing is the issue. (I’m doubtful tho) update: dead again
So now that it’s dead again I recheck Pin 3 and Pin 11 at OVD I have 2.48V and 2.42V is this off by enough to be an issue?
Based on all this info does anyone have any ideas? I feel like these readings seem to be okay not sure what my next step would be, I mean the one CCD like has a smidge extra resistance but it doesn’t jump around. I’m sort of worried about the clusters 120ohm resistor that when I test the one direction randomly drops to 102ohms. Not sure if it’s time to send my ecm and pcm out to be tested
Edited by teknic
Disconnect all optional modules one of them may be corrupting the bus and leave them off. If problem persists  then stress ECM with freeze spray or ice. Then heat with hot air.  Repeat. Watch display as heated or cooled. This can help rule out or rule in ECM. Intermittent problems need more than continuity checks and without known good parts to swap stressing is the only option.
So disconnect everything on CCD besides cluster/ECM/PCM and just monitor to see if gauge issue occurs while heating/cooling/shocking ecm?
That's right. One more thing make sure all the connectors on the back of the fuse block in the dash are seated good.
Ok so can’t find the Radio CCD lines, I have an aftermarket radio so not sure they exist anymore but I unplugged my radio, ABS and overhead console. Started truck, tach dead. I’m working on getting to airbag module, haven’t taken off the shifter tower before so may be a minute.
I also reached in and made sure all connectors were fully seated to interior fuse box, they were.
Also pulled apart the underhood fuse box, no signs of any corrosion or messed up wires down there Altho admittedly it’s hard to see
Alright got Airbag module disconnected, ran the truck, gauges still dead. So this at least narrows it down to wiring/ecm/pcm/cluster correct?
