P1694 and P1698, Diag help
Hey,
ive got a 2001.5 2500, 6-speed truck.
intermittently my tach/oil press/water temp gauges will stop working. Typically when this happens my engine also has a quick “kick” to it like it shuts off and jumps right back on. I never get the “nobus” message on my cluster.
if I check my codes I have p1693, p1694, p1698. Also randomly a p0501 code and ABS light.
I replaced my ECM for this issue 1-2 years ago but it didn’t change anything, but I used a reman one so not sure if it’s quality. The issue never went away though.
was hoping someone could help guide me through what wiring to check, or really just help me determine what my issue is.
I believe I’ve monitored my RPM with my zedge before and when my tach is dead the RPM still works on there as does Oil Pressure, but the Water Temp just stays in one spot until the gauge comes back to life on the dash.
any help is very appreciated, oh and I have no access to a DRB3
  • Replies 51
  • Views 14.2k
  • All right i will add it to my todo list while diagnosing this.
  • Great work!
    Great work!
    Because the bus is active and talking those voltages fluctuate. During a very long idle state which is very unlikely the voltages will settle.
  • Lol I threw an ECM at it once hahaha but I tested before that too, just not as thoroughly. Think I just got a badly rebuilt ecm. On the bright side I now know a lot of the wiring. I’ll definitely keep
oh and something I didn’t note earlier, when I had the harness apart moving it around didn’t trigger the tach to come to life/die
You need to be checking ac at alternator not on batteries. Big difference, battery is like a filter it buffs out ac noise. Do a wt mod for sure. Not saying you don't have other issues but WT is important on our trucks.
Checked AC from alternator stud to the negative terminal of both batteries, both showed same result .03-.04. Only other way I could do it is from alternator stud to engine block I guess?
I’ll certainly do the WT mod but I don’t think that’ll fix my issue, it’s more of a preventative. Before I spend any big money I will do the mod though, already got the 150A circuit breaker.
BTW should my CCD voltages have been exactly 2.51 and 2.49? Is the fact they’re 2.49 and 2.42 a sign of the issue or just normal variance?
Edited by teknic
Ok thanks, if you saw above I did as suggested running engine just off ecm/pcm/cluster and the tach stayed dead. I guess next thing I’ll do is the WT wire mod in case it’s a ground issue
Did you test the cluster? Hold the trip pin down and turn the key on. It should say Chek then release. The test will running at the end report error codes in the odometer.
Yes while the 3 gauges were dead I performed the cluster test, all needles moved correctly and at the end it saw codes p1693 and p1694.
Cluster codes are not p codes... Then the codes range from 900 to 999.. Only 3 digits.
So if there is no 900 to 999 codes then I'm stay in on the CCD network being the issue. You got to figure out what is messing with the line voltage if nothing can be found you might have to send the ECM and PCM for testing.
Attached are the codes the cluster shows.
yea I’m thinking the ECM and PCM need to get tested and gone over. Going to do the WT wire Mod first for the hell of it.
Only shows when you hold the trip pin down, then turn the key on, then the odometer will say "Chec" when you release the lcuster does its test then completes. In the odometer display these 3 digit codes will be displayed. If none display the cluster is good. So again this points me at the PCM and ECM.
Oh yeah the CCD bus on the stereo is a 2 pin plug. Same pair of wires as the ODBII plug. This was used for steering wheel control and so the digital signal could be recv'ed for volume up and down and tuner up and down on the steering wheel. If these 2 wires and shorting out because some one cut them up or hooked them to something could pull the CCD network down. (Errors).
ok yea so my cluster definitely shows no codes after the test, so it’s good.
Hm I couldn’t find any extra plugs at my radio, would this 2-pin connector be in the same bundle as the other 2 connectors? I have no audio controls on my steering wheel, just cruise control. I have 2 connectors that are like 6-7 wires each that go to radio, 1 antenna lead, 1 wire that is single pin slip on connector like how you see on oil oil pressure sensors, and then a big round plug that I think is the 6-disc changer. I tried reaching around and didn’t find any loose wires. Any chance you have a picture for reference?
Neither do I (no steering wheel controls) but still there is still a 2 wire connector with the 2 CCD Bus wires even on my truck. (vio/brn) and the (wht/blk) wires... ALL truck have this connector regardless of steering wheel controls.
That’s so weird I even just pulled up the service manual and see the radio C3 connector with 2 pins.
well I guess I’ll be tearing in there later maybe that thing is crushed somewhere.
do you know if it’s bundled with the 2 main radio connectors?
Alright I’ll rip into it and report back, I know there was no connector so I’m sorta thinking/hoping someone clip the wires somewhere and they’re randomly shorting
Just posting this pic for my own and others references, the radio ccd connector is “Radio C3” in service manual. Located in Figure 25 of connector locations. (Figure is from angle of you looking from firewall towards radio)
in the figure you can see it should branch off the C1 and C2 bundle just a few inches before the C1 and C2 connectors.
Actually your looking at the back of the dash assembly. Like if you had the dash pull out of the truck as you see the path of the wires are backward mirror image. They are heading towards the bulk head connector on the driver side.
Ok quick update pulled my radio and HVAC panel… 2 pin CCD Connector nowhere to be found, see pic attached. Pulled back that wire covering too, no cut wires no loose wires nothing.
If anyone out there could get a picture of their radio C3 connector and see/show where it comes from in the harness id be immensely grateful.
Mainly need to know where it comes from, because if it comes out the same spot as the end of that red circle I’ve got no clue where this plug went
Update:
Alright I decided to pull out Junction Connector 7, to the left of the steering wheel which is where all the CCD lines join. I looked at pins 17 and 20 which is where Radio C3 should terminate, they’re not there.
I think my truck just doesn’t have that connector, let me know if I’m wrong.
Edited by teknic
Ok so I think I’m going to send my ECM and PCM out to “Auto Computer Specialist” and see what they find, hopefully they can recreate my issue and I can get this solved and onto better ways to spend my time on the truck.
while it’s down I’ll prob finally swap the dash and all the HVAC stuff plus sound deaden and install my new black carpet
