- Replies 15
- Views 3.6k
Mikelilly84 5 posts
Mopar1973Man 3 posts
Silverwolf2691 3 posts
01_Cummins_4x4 2 posts
We can absolutely assist. Please contact us if you have any questions.
I love a company that pays attention. Well done.
I'm gonna say sensor signal. The computer wants to see something there even if its not signaling any data. For instance, I run a mechanical fuel pump on my truck. It had a gen 1 or 2 airdog on it. Whe
Hey guys new member here! Buckle up this is gonna be a long one. Lol I have a 99 3500 with a 6speed swap. Bought the truck not running from an auction. First thing I noticed when trying to get running was it had a lift pump in the tank that looked factory ran never seen that before. Got truck running by just replacing batteries. Install a fass 100. My issue is now truck runs and idles good but I have no tach , power loss , and extended crank sometimes and a crank sensor fault. Replace crank sensor 3 times no change. So my thought was tone ring so I pulled starter and sensor to try and inspect tone ring. Here’s where it gets weird. I don’t see a tone ring? All I see through the hole is the crank when it comes around and it take up almost the entire hole. It also is slightly rubbing the crank sensor. My thought is maybe an 01 block? My buddy has Cummins insight and the engine number on the front cover has a build date of 7-2000. Im at a loss of what to do next cause I know motor isn’t original and idk if it has the right ecm on it. And to top it all off is when I unplug the crank sensor truck will not start. What is it reading the crank counter weight lol I’m at a loss. What should I do next? Any help or insight would be greatly appreciated
