How to add more ignition-hot fuses?
- Replies 6
- Views 1.4k
IBMobile 3 posts
Mopar1973Man 1 post
wil440 1 post
YeaImDylan 1 post
Hey all, so I'm in need of more fuses for accessories and what not. The previous owner when hooking up the quadzilla used some type of pigtail add a fuse which had a small metal piece that was flat and then the other end went down around the pin on the #9 engine fuse. I'm wanting to do an actual add a fuse but I have 2 accessories already running off ignition hot sources in the fuse box and there isn't room for me to put the add a fuse on #9 for the quad. Geno's garage I believe used to sell a "painless" wiring fuse box for ignition hot sources but I can't seem to find it these days. I want to run the gauge cluster and air dog to the new block so I have room to do the correct add a fuse on #9. If this confuses anyone in what I mean, I can post pictures and explain better. Biggest thing is the fact that the add a fuses I have in the fuse block are taking up room next to or underneath #9 so I cannot fit another add a fuse on #9 for the quadzilla.
Thanks!
Dylan
