Copper Extreme Duty Battery Terminals for Jeep Wrangler
- Replies 5
- Views 2k
Mopar1973Man 1 post
jlwelding 1 post
wil440 1 post
Andyba20 1 post
You need military style terminals then just copper lug the cables. I just done a 2006 Dodge back this summer and turned out good.
Crimped ( Hexagon controlled cycle -- compression style) is the way to go. Also use sealant lined battery cable heat shrink tube to seal fitting to cable and closed end/tinned battery lugs for best r
My battery post are on the verge of breaking and trying to avoid the expense of new cables. If you do a search for these it comes up with like three connections on each terminal. If someone wouldnt mind checking these out? I tried to get a pic to post but I'm not good at that at all.
