Puke Bottle Question
After I rebuilt my engine I lost the puke bottle and just left it off. I have what appears to be several little oil leaks under the engine and front axle and differential is wet also. Can the hose coming out of the crankcase be dripping enough that it blows everywhere and causes several leaks or could I have several leaks? Everything looks dry along the valve cover, head, and block.
  • Replies 23
  • Views 12.8k
It is called opie's coolant bypass kit.No cooled turbo.Your correct it goes on the head between 5&6 then runs to a manual valve.When the pressure gets high it runs coolant through it.I use to be big into dragracing with my truck.Not so much now.Money is hard to come by these days.
OH yeah Steve openowski aka opie. I met him at the NHRDA races in Billings a few years ago, I bought my billet op shaft from him. He has some good products.
  • 9 months later...
I was out wheeling in my rig in the mountains and was on a downhill slope id say about 35deg down or so (standing on floorboards) and my oil pressure dropped fast, luckily my gauges warned me and i shutdown in time to avert engine destruction. Well when i finally leveled out i checked oil level and restarted. I lost a gallon of oil on the downhill slope from the damn vent. (cleaned up what i could find)So later that week i read up on the problem and found that anything over 22deg down slope and oil will run out of the engine. I found Moparmans writeup on it and i performed the mod.$10 later and the 1/2" pvc pipe run over the engine to the backside and i have never lost a drop since. I may get a drop once a week out of it just from condensing vapors but i plan to attach a 1 liter bottle with thread adapter to it for a catch.I have tried the mod out on steep declines since and no issues.
I've found that if you hang on the slope too long it may start to gurgle out some oil but it takes much more effort for it to occur. :smart:The only reason for the mod was like you I travel some steep mountain slopes fishing for firewood... :lmao2::lmao:
