Oil leak after vp44 replacement
- Replies 24
- Views 6.5k
connors 8 posts
Mopar1973Man 5 posts
wil440 4 posts
IBMobile 3 posts
Popular Days
My experience with oil leaking on the driver side of the engine sounds like your story. PULL THE VP, vacuum pump & steering pump. INSPECT the tappet cover & the plate that seals the old mechan
I just use the standard front crank seal on mine. No nee for sealants or anything just tap the seal into the cover and then install the gear case cover with grey RTV sealant. If you have a bad groove
Hi, I was woundering if anyone can help me diagnose a oil leak it started after I had my vp44 replaced on a 2000 5.9. It is just pouring oil out fromm some where on the front of the motor on the drivers side I have tried cleaning the motor to see where it’s coming from. I have already replaced the front seal the crank seal and I have rebuilt the vac pump. I looked around the vp44 checking for a leak but it is dry all the way around is there something I am missing. Thank you
