- Replies 59
- Views 8.1k
Andyba20 16 posts
Tractorman 11 posts
Mopar1973Man 9 posts
JAG1 7 posts
Gather a pile of cheap tools off of Ebay or yard sales or wherever ( if you haven't already got what you need) 99% of tools do not have to be expensive Snap On or the like And stay a mem
Sounds like the shoes are rubbing too tight need to adjust, unless the emergency brake is staying on slightly. Don't listen to W-T he hardly ever drives his truck so it squeaks like that a
Thank you @Tractorman indeed my suggestion was NOT with engine operating... In several additional reviews of @Andyba20 video it is pretty easy to see the velocity of the rear universal joi
Is this a ujoint or something else? Noise only happens in reverse gear with engine running, no noise when backing in neutral with the engine off. Noise disappears when in forward gear.
