2001 Dodge 2500 Heat Exchanger Replacment
- Replies 10
- Views 5.3k
IBMobile 2 posts
LorenS 2 posts
Vinster_Beta 2 posts
VMac822 1 post
Vinster I just switched my truck to manual and will sell you mine for cheap like $50 if you pay shipping. It's not rusty since my truck has always been in a mild climate.
You might want to look at the ISSPro EV2 Trans Temp gauge for the fan controller. You can get the USB program cable and program the optional relay for a set temperature to turn on the fan and then set
My current Heat exchanger is a little crispy after the 20 years of service and a few years around some road salt. I've seen several listings on Heat exchangers varying in prices from ~$800 dollars to as low as ~$200 dollars and curious if anyone has found a difference between them or has had issues with the different options out there. Trying to save penny's where I can without risking the reliability of the truck.
Eventually I also do plan on adding an additional cooler in the loop but curious if size of the cooler will add (if such a thing) too much restriction.
And lastly, currently I have my Trans Temp sensor located on the output of the trans, but I have read about people mounting it after the Heat Exchanger due to more stable/ accurate temp. I am curious on opinions on that. I tow a lot with it and trying to keep everything as happy as possible, eventually ordering a new valve body is on the list here in the next few weeks and hope to see temp improvements in that as well.
