- Replies 16
- Views 3.9k
Mopar1973Man 6 posts
Unreal Summit 5 posts
dieselautopower 2 posts
Max Tune 2 posts
Popular Days
Dying when you put it in gear is related from too high of pop pressure and bigger injectors. Automatics are more susceptible to the stalling.
Yup getting down to the bitter ends.
This happened to me all the time while the truck was cold, especially shifting into Drive (Reverse was ok). After it warmed up for 5+ minutes it wouldn't stall. Then after I had my trans rebuilt the c
Drove my truck this morning and just happened to look at the idle speed when I got to work. It was at 822-825. The coolant temp had gotten hot enough to open the tstat. However at the time my temps were showing 180ish. So would this be a reason why it's idling a little higher than normal? Idk why i pay so much attention to my gauges but I guess it's a good and bad thing 😆
