VP44 replaced, Injectors replaced, now P0112
- Replies 19
- Views 3k
Tim Waldo 9 posts
Mopar1973Man 8 posts
Great work! 1 post
VMac822 1 post
If you purchase a Bosch Certified pump it should have a NEW PSG module. If so it is sold blank which means it will be ran on a Bosch 815 test stand for 3 hour to calibrate and test. After passing all
Ok, I know things can cascade, now I'm wondering what all sensors I SHOULD replace. Started with a replaced VP, was running rough and lots of white smoke.... so replaced with remanufactured Injectors and new tubes... still white smoke but was improving. Scanned for pending codes and nothing showed up. Took for a test drive the smoke cleared up A LOT but still loss of power going into 3rd gear and again going into 4th gear... and then it just shut down on me with a code of P0112... fired right back up and got it home with the same power loss on gear changes.
Can an IAT shut the engine down?
Should I replace any other sensors?
I replaced the IAT, MAP and Crank position sensors all in 2008. Just because, no codes were being generated, Crank position sensor was replaced in or about 2013 because it was throwing codes.
Thanks,
Tim
