Fuel hose anti spill valve needed
Recently installed a flatbed on my 99 3500. Could not use the original filler tube with the anti spill valve, Now I'm taking a bath every time I fill my truck with fuel. Not sure I can remove the original one without breaking it. No luck finding one on the net or local parts store. Anyone got a source or an option?
  • Replies 10
  • Views 3.3k
  • https://www.perko.com/catalog/fuel_system_components/313/special_application_inlet_check_valves_-_flapper_valve/ I always check the boating industry for unusual things.... I'll add this also..
  • Royal Squire
    Royal Squire
    @LD-OrdieThat Perko check valve is on Amazon
  • My flatbed doesn't have the anti spill either. I have to fill so slow that I cannot use any of the nozzle fill notches that holds the nozzle in the on position or they fill too fast and then shut off
My flatbed doesn't have the anti spill either. I have to fill so slow that I cannot use any of the nozzle fill notches that holds the nozzle in the on position or they fill too fast and then shut off after spewing out fuel everytime. I use my utility knife to hold the handle in the on position and fill so slowly I can hear the fill pump squeaking while filling my truck. LOL, I think I get more fuel than I'm paying for that way. Takes about twice as long. I have to turn on the key and watch till the gauge says its near full and then get out and listen for it to come up to full on the fill neck. I shut it off before spewing out.
This looks like the hot ticket! Thanks for the links
I checked out the source, they will only sell to a dealer. They shared their 3 dealers within 200 miles of me. None of them had one in stock, and required buying a minimal of 5 units, which none were receptive. So gotta start calling around beyond my local area for a stocking dealer. Not giving up!
Biggest thing I've seen about flatbeds and filler necks is make sure the vent hose has a downhill run fully to the tank from the neck. Make sure that no fuel can puddle in a sag of the hose. Then do the filler hose the same way. Thor is a flatbed too but no issues with filling even with a high volume diesel pump found at most truck stops.
Installed the new valve, worked as advertised ! One complaint is that it is a flapper valve with a spring keeping it shut. I add 2 stroke oil to my fuel, usually after I'm done filling. Being the valve stays shut, I now feel the need to do a rough calculation as to how much oil to add, and do so before I start fueling. The valve is not a tight fit in the hose, so I supposed the oil would eventually work it's way into the tank if I add more after fueling.
 So are you running some sort of valve on your flatbed?
