Quadzilla Injectors
So back in April DAP sends an email launching the new Quadzilla injectors, but they don’t sell them on the DAP website. What’s the difference in the Quadzilla injectors vs the new DAP injectors they sell on the site? (Besides the green rubber seal)
  • Replies 6
  • Views 3.1k
  • dieselautopower
    dieselautopower
    Hi,  The Quadzilla injectors are all loaded on the back end of the DAP website.  That was done pre-launch and we missed the part about activating them.  That will be fixed shortly.   Quadzil
  • Doubletrouble
    Doubletrouble
    Was there possibly a difference such as VCO vs. SAC style injectors?
So... Let's look at the facts of an injector. What can you change about an injector?
  • Nozzle size and hole count
  • Pop pressure
As far as I know, the body of the injector typically doesn't change at all. The rest of the internal parts other than the nozzle and pintle are machine as a matched pair. Again the hole count and hole size can be changed and then the pop pressure.
So why confuse your customers (DAP) with 3 different flavors of injector, and only sell 2 of them at dap.com? They have a 75hp injector set for $369 (which I assume are reman’d), they have another 75hp set for $546 (brand new), and then over on the Quadzilla site they have 75hp injectors for $699. Are DAP and Quadzilla not the same company in the same building?
Yes but that’s never justified a price difference in the past. Plus it doesn’t explain why DAP wouldn’t sell the Quadzilla brand on their website. They sell everything else under the Sun, why not injectors made in their own building?
  • Popular Post
Quadzilla injectors are different from DAP injectors and not just the o-rings.  It is a premium injector.  Quadzilla Injectors are all brand new components, built with new bosch nozzles and new bosch bodies.  There is also no core deposit.  We have a number of people running them.  Some have been running them for a while before Quadzilla launched the new line.  We have someone that changed from a name brand 6x.016 to QZ 8hole big sac and the customer has MORE fuel, and LESS smoke and spools faster.
The DAP injectors are more value based and I would ague better than injectors that competitors charge hundreds more for.  They are EDM, honed and flow/match balanced to .03LPM and bigger injectors (typically above 5x.012 for 12v or 7x.0095 for 24v) also have tip mods done... all at no extra cost.
Both lines are hand assembled and them pop tested on digital equipment.
