- Replies 6
- Views 3.1k
Mopar1973Man 1 post
ISX 1 post
jncornett 1 post
bjytech 1 post
My front end makes a really loud knock through every single bump and vibration it encounters. I remembered my bolt on the shock looking like this when I changed them but had to get it back together and just ignored it. Only the passenger side looked like this, the drivers side was fine. The shock bushing had so much play it could bang each side of the bolt, and it was incredibly loud. So I got some 10.9 hardened bolts that don't have the thread so far up to wear out that should last forever. Went ahead and did both sides. Got some locknuts so I can do away with that big tab thing. I don't know why they did that tab thing when you can get to it with a wrench easily. Maybe a squirrel slayer or something was it's intended purpose.Knocking problem solved. Maybe this will help someone else.
