- Replies 20
- Views 4k
Mopar1973Man 7 posts
Tractorman 6 posts
dlg 6 posts
JAG1 1 post
@Mopar1973Manwill likely reply at some point, but I know he will want a bit more information. He is the residential expert regarding the Quadzilla. He can provide you a custom tune. Auto
When would it be hugely beneficial to be not locked up in 4th? An unlocked converter generates heat, lots of heat - the heavier the load and the further the throttle is pressed, the more heat will be
@dlg , you bring up a lot of good points and I completely understand your frustration. A stock 47RE is not a good transmission to have behind a Cummins 5.9 liter engine. You have listed all of the s
Let me start by saying I know there is a lot of existing information on the forums but I have never tuned any gas or diesel vehicle before, and this is my first diesel vehicle so i'm just not comfortable figuring it out on my own. If you are annoyed by folks who ask already answered questions I would just ask that you move on to a different post.
I have one generic question and then a few tuning related questions.
First, the general question. What is the best way to go about finding a shop, or a person near me who has the ability to enable the factory high idle and 3 cylinder high idle in my ECM. I am located in Omaha so bonus points if you already know somebody or some place. I do have access to an Autel scan tool that I usually use for reading codes, is it possible I can do it myself? The Autel does a lot of things that I have never messed with so I don't know its capabilities.
On to the tuning questions. I would rather pay someone experienced to help me with this, rather than try to figure it out myself and mess something up. If you are interested in helping me, please let me know.
I have an (as far as i'm aware) stock 1999 Ram 2500 and I have installed a Quadzilla. I have highway gears and so towing at speeds over 60 can be tough. I don't want to change the gears out because I don't tow that often but I drive on the interstate a lot so as far as pros/cons go the highway gears are better for me. I also don't tow anything that heavy, mostly an enclosed trailer with a lot of drag and not much weight. From what I can tell after installing the tuner the real additional power doesn't kick in until after 2000 rpm which from what I can tell is based on the timing settings in the tune. Unfortunately my overdrive kicks in around 45-50 mph and I don't hit 2000 rpm until about 70 so it's still tough to get from 45 to 70 even in PL10. Once I'm at or over 70 everything is great. So is there anything I can change to safely get some of that additional power between 1500 and 2000 rpm?
Second question. The Quadzilla has a 'mileage' setting. I have not had it installed long enough to know how effective that is, but is there anything I can change on this power level to make it more effective without causing issues? This would only be used when i'm running empty on the highway. If I was towing or hauling I would use the stock setting or one of the increased power levels.
Third question. Should I add the optional fuel pressure sensor? I do not intend to do any additional mods to the engine.
I don't really want anything crazy here, I don't want to race this thing, I don't want to do a bunch of crazy mods, and honestly from what I can tell I don't even really need PL10. Just going to 5 or 6 makes the truck much more drivable when towing. All I want to do is make the truck as driveable as possible without doing anything that could damage the engine.
Thank you for your time.
