- Replies 8
- Views 988
nicor 3 posts
Mopar1973Man 2 posts
IBMobile 2 posts
Doubletrouble 1 post
Popular Days
Use military style terminals then used copper crimp ring terminals. That way when the lead terminal get damaged you can just unbolt the rings and change a terminal fast and easy. Do NOT ge
Hello, im new here and to the 2nd gen community. Just picked up a 1999 dodge ram 24v a week or so ago from my uncle. Truck has sat for 5 years but fired up first try when i put a new driver side battery. secondary battery sits at 12.4v after charging it but primary wouldnt hold a charge. First drive, the car would approach redline at 30 mph, but after like 2 minutes, it fixed itself. Then i had the dreaded unlocking/locking of the TC around 45-55 mph. I did the @W-T ground and alternator wire relocation and now it does not like to shift or lock the converter when im on the highway. At 60 ish mph rpm is at 2500. I did the APPS reset after waiting a few hours with the battery disconnected and hooking them back up. Unplugged and replugged the PCM as i read somewhere that it helps in some cases. Transmission fluid looks to be nice and red in color. i hear these transmissions are kinda junk but i dont mind tearing into it as im pretty mechanically inclined. I just do not want to start wasting money at buying parts that i do not need. Looking forward to getting some insight. Thanks.
Forgot to mention, i also have 0 codes other then the block heater which is disconnected as i live in California. Not sure why they are disconnected, but does it harm anything?
Edited by nicor
