Poor fuel MPG
Checked the Mileage when I topped off this afternoon, and  found that I got 13 MPG. Now granted it's winter, and the truck idles more, this is still pretty crappy.
The particulars are as follows: 1998.5 3500 24v, edge EZ box, DAP 100hp VCO sticks, New OE size tires (215 85 r16) 400,000 Miles 5 spd trans. I'm planning on jumping on the quadzilla train this spring, but does anyone have an idea why my mileage sucks so bad?
Mark
  • Replies 35
  • Views 6.1k
  • Tractorman
    Tractorman
    Have you done the IAT sensor fooler with a resistor yet?  I use a varaiable resistor that sets the IAT sensor reading at 143° all the time.  This really helps for winter performance and fuel economy.
  • Tractorman
    Tractorman
    Mine has been on my truck for about 8 years.   I will take a photo of it tomorrow and post it here.  From what I remember, it is a 5,000 ohm 1/4 watt variable resistor.  I mounted it in the engine com
    I'm working on bringing my high idle kit back to market. I'll keep you all posted.
Some of the early articles talked about 19 to 20 BTDC at 2k RPM. Which I figured out is wrong. Timing is based off your pop pressure and how far is strays from the 310 bar which is 4,500 PSI. I'm at 320 bar with 4,641 PSI which is about 2 degrees retarded hence why I can reach 26degrees at 2k RPM with timing. Now someone with a low pop pressure say 290 bar could be about 4 to 5 degrees advanced and would have to retard timing. Just seeing his running timing he's retarded to deep yet. Should be some where around 22 to 23 degrees at 1,900 RPMs.
Take some time watch stock timing on level 0. You can add about 2 to 3 degrees more over stock. Only one catch cruise timing has to have 5 PSI of boost or LESS. Don't wanna blow head gaskets.
I bought a tow tune from Mike a year or so ago. He called me last spring and we talked a few "numbers" as I had contacted him regarding a high engine load at cruise. He said it was due to the drag in an auto transmission vs a manual. Since I have the quad and have been driving the same 50 mile round trip commute for 29 yrs now, I want to see if I can get it as fine tuned as possible as I see very different numbers (engine load, boost, egt, timing etc) vs what he has mentioned in some of his threads. He's the guy with the knowledge so I'm hoping he can find me another few mpg! :) Thanks Mike!
So do the same data collection at Quad level 0 instead of level 3 where I normally operate at?
Please look back at my past post fill in the numbers please.
didn't I get you the correct numbers in the post about 6 and 8 posts above? Let me know if I didn't get you the correct info in those two posts.
Edited by 5akman
Timing displayed is what is commanded. So level zero Quadzilla is disabled. Level 2 is stock fuel. Level 3 is CanBus fuel.
Timing is more important than fuel. But don't have excessive fuel in your cruise state. This why the 100% stock realm for your cruise state.
Here you go Mike:
55mph = 1600 rpm, 2 psi, engine load 21, timing 16
65 mph = 1900 rpm, 4 psi, engine load 23, timing 19
65 mph with slight grade = 2000 rpm, 7 psi, engine load 32, timing 14
light throttle load limit 27%
Light throttle timing advance 2%
1500 = 13
2000 = 17.5
2500 = 22
3000 = 26.5
I'll get Quad 0 data on the way home from work today
Edited by 5akman
Prior tune data/results as posted earlier in this thread:
Results after our phone conversation today:
55mph = 1600 rpm, 1 psi, engine load 24, timing 13
65 mph = 1900 rpm, 4 psi, engine load 20, timing 21
Engine oil temp is about 7 degrees warmer than coolant temps.
How are you guys going down the road with such low boost numbers? Typically I'm at:
55mph, 1600 rpm, 4-5 psi
65 mph 1950 rpm 9-10 psi
This is on flat land to.
Mark
Timing is too retarded. More retard in the timing more fire and expanding gases are sent to the turbine to spool.
More you advance timing, More the fuel is burnt in the cylinder leaving little expanding gases to spool.
Excessive advancement can possibly blow out head gaskets. The trick is to make sure you drop your high timing before boost is made. 5 PSI or less you can run like me 26 degrees. But as soon my load changes it drops to 18 degrees.
Poor final ratio. I can tell your on stock tires and too low in the RPM band. I'm running 2k RPM at 66 MPH. Then at 82 MPH I'm twisting 2500 RPM. I'm running 3.69:1 final ratio after tires.
Ok, Looks like I'm getting that Quad a little before I planned. Now as far as Poor final ratio, I may be off my 65 mph rpm since I don't have the chance to get going that fast very often, but by my calc it's about 3.70 with a 3.55 gear and 215 85r 16 tires. Am I missing something?
Mark
Edited by Scarecrow
poor information
Ok, ordered the Quad today, and the took a drive around the county.  New intel is:
55 mph, 1625 rpm, 4-6 psi
60 mph, 1850 rpm, 7-8 psi
65 mph, 2000 rpm, 9-10 psi
Sounds like I need to advance timing a bunch, what about fuel? I'm new to the quad thing so any input would be welcome and  apricated. I know  how to make a 440 run like a raped ape, but diesels are a new thing.
Mark
Fuel table is selectable but I'll warn that if you are attempting for efficiency then you should be 100% or less for fuel table. I typically ride in my defuel table between 0 and 5 PSI. I can climb 7% grades without using any additional fuel above 100% even on higher levels. Hence why temperature are lower. Even while running 200°F thermostat.
Thermal dynamics basically states greater differential between temperature will make them attract to each other. So cold is attracted to heat and heat is attracted to cold. The whole idea is reduce the amount of heat dumped in coolant and oil.
Ok, I'll wait until the quad shows up and then start playing with that. Until then, I've still got to do a leak down on the road runner, and then work on the kick down linkage on the Ramcharger. Between that and calving there's just way to much stuff needing work, and nowhere near enough time or money.
Mark
