2000 Cummins Surge/Dead Pedal
Hello everyone,
New to the forum here, have a 2000 Dodge 24 valve. I’m a mechanic by trade, bought the the truck off one of our customers. He had this issue towards the end of his ownership, truck would surge during idle and the odd time would throw APPS code but he could still drive it.
The trucks had a couple different APPS sensors, OEM and aftermarket. When I bought the truck last summer I did a ton of upgrades/maintenance, starter, alternator, 2 new batteries, FASS and sump, fuel pressure gauge and a bunch of other things non related to the problem. I did all the APPS testing between sensor and ECM and everything checked out.
After doing the timbo APPS my issues seemed to go away (the alternator change was around this time too). We have a truck bed camper and went on a couple long trips with no issues. I don’t drive it much in the winter but again when I did, no issues. The start of this year also had no issues, and then things slowly started to creep back. I’d be sitting at a stop light and truck would kick up a bit, started becoming more frequent, and now it’s dead pedalling again, I’ll take off for work in the morning, I’ll be trying to come to a stop and RPMS will stay high, then 2 minutes later CEL comes on and no throttle. Takes me a while to get into the system with my scanner, I’ll clear it and I can drive but will either rev real high right away and trip the light or it’ll throw it a minute down the road again. But then if I work through it enough times, and the truck warms up enough I can get going with no issues. I can go somewhere, shut the truck off, go in somewhere and drive all the way home, again no issues. But if the trucks cold or sitting for days it’ll give me issues.
I checked for AC noise and am getting 0.127V, is this possibly an alternator gone bad? Like I said I replaced it last year with the timbo and was good for awhile but now a year later dealing with the same problems. Just want to make sure I’m not missing something here. Seems weird to me that it goes away when the truck warms up. Any insight would be greatly appreciated!
  • Replies 55
  • Views 13.1k
  • Tractorman
    Tractorman
    Sounds like  you have been thorough in taking care of things since you acquired the truck.    Have you checked the conditions of all battery connections and frame / body wiring grounds?
  • I would do this step, first.  It would be good to know whether or not a false signal is being generated at idle.   Since the DTC states, "Idle Validation Signals Both Low Problem detected wi
  • Tractorman
    Tractorman
    It sounds like you have confirmed that a false signal is being generated in the APPS output circuit. It would stand to reason that the engine rpm's would increase if a signal is present. Back to a pr
Most Helpful Posts
  • Tractorman
    Tractorman
    This doesn't mean that the APPS is faulty - it just means that there is an output signal at idle when there shouldn't be. Need to know where it is coming from. More troubleshooting needed. Since I d
Well, that's a bummer!  Any codes?
You could hook up a scanner and monitor the throttle position on the display.  Drive the truck and when the symptoms occur at idle, see if the per cent of throttle changes on the display, or if it remains steady as it should.
I think that you may still be getting an electrical interference of some kind.  I don't know much about the ECM operation, but I think the ECM has the capability to monitor and weed out false signals.  However, if too many false signals are being sensed in a specific amount of time, the ECM may consider the signals to be valid.  The APPS provides one of those signals.  It may be worth a try to leave the ignition switch in the "Run" position and slowly depress the throttle to the floor one time and release.  Turn the ignition switch off and then start the engine.  This is not a fix, but if there is electrical interference with the APPS, then the symptoms may disappear for awhile.  This may help to diagnose what is really going on.
- John
  • 4 weeks later...
- John
Hey John,
Thanks for the reply, was away for a bit and then was driving my TDI Jetta, have been driving the truck, the pedal reset seemed to work for a couple days. Then it started acting up again, now that it’s happening on almost every single drive I’m going to check the throttle position on the scanner while it’s doing it. But it seems to be getting worse.
It’ll be revving high when I’m trying to come to a stop, doing it at idle or even while cruising it’ll surge up and then come back down. Saturday I fired the truck up and it went straight to 2k RPMs, shut it off and turned it back on and it was fine, kicked up a bit leaving but like before once up to temp it’s USUALLY okay, it has done it the odd time once warm but it’s rare.
It’ll throw a code still but won’t dead pedal, it throws a P0222 Idle validation signal code. A weird thing I noticed if I plug my mini scanner in it takes forever to get all the monitors to run, but the CEL just disappears when you plug it into the OBD. No issues with snap on scanner.
Is it possible I have an injector issue or oil issue causing it to idle up like it has been?
P0222 (M) Idle Validation Signals Both Low Problem detected with idle validation circuits within APPS.
I would definitely find out why you are getting this code.  If the ECM does not get a signal for idle validation, then the engine rpms will not go to idle.  Which APPS are you using now - OEM or TImbo?  Either way, you could try adjusting the mechanical stop where the APPS is located in the engine compartment.  Back it off an extra distance to ensure the throttle will activate the idle validation switch that is built into the APPS.
I seriously doubt that.  An injector misfiring would likely cause a miss or a timing knock.  Engine oil feeding a cylinder wouldn't allow the engine to shut off immediately when you switched off the ignition.
I think the P0222 in telling you something.  Double check all of the pin conditions in the connector to the APPS.
- John
Thanks for the info John!
I have the timbo APPS, do you think it would be worth back probing the green wire and adjusting the set screw? I know the previous owner had an issue with the set screw backing itself out but this is an entirely different assembly than what he had when that happened.
Since the DTC states, "Idle Validation Signals Both Low Problem detected with idle validation circuits within APPS", I would double check the wiring condition and connections from the ECM to the APPS - and, maybe try another APPS, if you have one available.
Also, I believe that you said you did the W-T wiring modification.  If so, re-check your work regarding Splice #165 - the ground for the APPS, ECM, and other sensors.
- John
Edited by Tractorman
  • 8 months later...
- John
Hey guys, been a bit since I last posted.
I didn’t drive the truck much over the winter but when I did zero issues. Now it’s warming up outside here and starting to have problems.
Drove it last weekend and took me 20 minutes to do a 10 minute drive. Dead pedal and revving up on its own. Sometimes it would dead pedal and id pull over, wait a minute and then the throttle would be back without clearing the codes. It would happen again and sometimes I would restart it and it would start revving high right away at the same high RPM like when I shut it off. Eventually I left the code and kept trying to get where I was going IMG_9959.jpeg
and it surged a bit while I was driving but eventually ended up being okay.
I brought my multi meter home from work and checked for AC noise because I’ve been suspect of the alternator. With the truck running right away with lights, radio, defrost heat, grid heaters, etc. I was reading .112-.185 depending if heaters or compressor clutch was cycling. With heat shut off I was reading about .071 and seemed to be coming down as truck ran longer but I usually have problems when I first start driving. From what I’ve read these readings are way to high? Am I looking at a new alternator here?
If so what’s the go to? Looking at getting a 170 amp and have looked at nation and mechman.
Thanks!
Talked to someone today at a alternator/starter rebuilder spot, and the guy makes wiring harnesses and rebuilds alternators and he said those values are fine but sounds like I have a wiring or ground issue, especially since after I did the WT ground mod it was better for a few weeks then came back.
Was saying that sounds like when I did the ground mod I had “touched” whatever the problem was or affected circuit since it did get better for a short amount of time.
This is one of the few reasons I would typically suggest to have the alternator bench tested for AC ripple at the time of the w-T ground wire mod install. Kind of hard to fix a noise issue if the alternator is still screaming into the charge wire. The ground mod helps with the noise not hoping back on the ground strap to the ECM and VP44.
Yeah that would have been a good idea. What would you recommend as next steps? From what I’ve read online my readings are way high, but from the guy I talked to yesterday he said they’re fine. Should I pull the alternator and send it out? I was going to try driving it this weekend with alternator unplugged and see what happens.
Pull the alternator have it tested. My test is under no-load to see the AC ripple. Typically a OK range compared to full load which the AC ripple will typical be higher that 1.0 Volt AC.
Haven’t had time to pull alternator but took it for a drive this morning, started acting up right away. Shut it off and got out unplugged alternator. Truck ran great for a couple blocks and then started doing it again, if not worse than when the alternator was plugged in. Still throws the same code P0121 and I’ve got a P0382 which is unrelated I’d think.
Any insight which direction I should be looking now? APPS? ECM? VP? Wiring?
Did what John said and pinned out between APPS and ECM and got these readings.
25 .2
32 .7
31 .2
All in ohms.
Edited by DunnerCummins24
25 .2
32 .7
21 .2
If you checking just the wiring harness only (APPS and ECM both disconnected), those readings should be around 1 ohm or less. Did you verify for accurate readings by testing your leads on your multi-meter first?
  • John
  • John
Hey John,
Yeah did test on meter first. I’m gonna try 32 again and wiggle the harness and see if anything happens. Is it worth checking the other 3 pins?
Gonna spend some more time in there this morning.
3 hours ago, DunnerCummins24 said:
Hey John,
Checked all 6 this morning from connector to ECM and .2 for all pins, even 32 which was reading higher yesterday. Wiggled the harness and pretty much stayed the same.
Key on terminal #5 am getting 5.1 volts.
Checked between the pins too for shorted together wires and nothing.
Put everything back together, plugged alternator back in. Cleared codes and did a APPS reset. Drove the truck for 10 minutes zero issues. Couldn’t even get 2 minutes past my house yesterday lol
17 hours ago, DunnerCummins24 said:
25 .2
32 .7
31 .2
All in ohms.
First, I misinterpreted your numbers. I thought they were readings in the whole number and decimal form. I see now that they are the wire number and a reading in decimal form. Those numbers are good.
Yes, these are the relevant wires. The DTC that was set referred to the Idle Validation circuit.
As I was typing, you were replying. The wiring circuit looks to be good. Did you re-check Splice #165 for a proper ground (from Pin # 11 on the ECM)?
I suspect that the symptoms will resurface.
  • John
  • John
Thanks for the reply John.
Splice 165 is where the 4 wires were taken to the back of the timing cover all together? If so that splice is good.
My battery cables are as old as the truck and same with the main grounds coming off them. Not sure if it would be worth changing them? Was looking at a 240a mechman alternator with the full kit to change all the cables. But by the time I get it to Canada I’m looking at 1700$ and probably isn’t going to fix it, would just be nice to have that done.
I have a suspicion of the ECM, but not 100% sure there either.
That would be the one.
I still have all of the original positive cables and ground cables on my truck. Periodically, I perform a voltage drop test (using the starter as a load) and I check each circuit individually. In my opinion, a voltage drop test is the best way to determine if an electrical circuit is in good condition. It is conclusive and never lies, and it stops you from wasting time and spending money on unneeded parts. The best part is that you don't have to take anything apart to perform the test, which is really the way you want to do it - actual circuit operation in real time, nothing disturbed.
I am also using the OEM alternator (a Bosch). No matter which alternator you use, there is always some AC ripple. Good batteries and good wiring practices absorb that ripple to the point it does not interfere with electronic devices. I have had a few conversations with W-T (a very knowledge man when it comes electricity). The primary reason he installed a Nations alternator was because it uses twice the number of diodes. That was important to him because he is an avid ham radio operator and he really needed clean electrical circuits. He even took apart his lift pump (the worst contributor of electrical noise) and added components to filter the noise.
Personally, I wouldn't go to the expense of the Mechman alternator and wiring kit - I would just perform the voltage drop tests and replace any cable or clean any connection that showed excessive voltage drop.
  • John
  • John
So weeks ago I did perform some voltage drop tests on a bunch of the cables, a lot were like .1-.2, one was .5 I think. Again truck ran great after having the ECM unplugged and doing all those tests. Then we left to go camping last weekend and of course acted up, really just idled high at 1100 and surged a bit but got us there and was fine on the way home. Went to take it for a ride this morning started increasingly slowly idling higher and higher, kicked back down for a couple minutes then snapped to like 2000 and then I just shut it off.
I have been cruising around with scanner on and watching the APPS pid and have noticed with no throttle input I am getting an APPS %, I’ll attatch a picture from this morning when it was acting up and foot wasn’t on the peddle. Tried a APPS reset after it was idling high this morning but that’s when it snapped to 2000 after that.
Thinking it has to be electrical the way it can just go away for weeks when I’m messing around in there? Really leaning towards the ECM now.
Glad to see you are performing voltage drop tests. Which wire has the .5 voltage drop? I am assuming that you are using the starter for the load while reading these values.
I have a Timbo APPS on my truck. I will test it with my OBDlink LX for behavior at idle when I go to town later, and then report back.
  • John
