47RE kicking out of O/D
I said i'd have some questions about my dads truck so here goes...
2001 Ram 2500 24 valve, 47RE automatic. Transmission was rebuilt years ago before he had the truck. not sure what all was done to it specifically.
It will randomly kick out of Overdrive sometimes cruising around 55mph, sometimes cruising at 60/65mph. It will kick in and out of overdrive 2 or 3 times in a row and then go back in and hold.
When he first described the problem to me i wasn't sure if it was O/D or Lock up giving an issue.. So i did the first test in the Alternator noise thread about isolating the alternator by removing the field wires and removing the 140 amp fuse in the box, went for a drive and the problem persisted and i was able to see that when it drops out it goes from cruising at around 18-1900 rpm at 55mph to 23-2400rpm at 55mph, so at this point i was certain it was Overdrive dropping out and not TC lockup.
Now my next question is he has a P0122 'A' code for APPS sensor, could this have an affect like that? We've done that APPS reset procedure for the heck of it and it had no change on the problem. I'm not sure if the APPS has any play into transmission shift control or not.
Edited by TCMagnum
  • Replies 21
  • Views 4.4k
  • WT mod should be done in full first. I don’t have much troubleshooting experience with autos as I have the 6 spd but from what I understand a lot of issues are solved when the mod is done. At least yo
  • @TCMagnum, Good job determining that that it is actually downshifting to 3rd gear.   I don't think you have an AC noise issue, although performing the W-T ground reference mod would be a goo
  • 01_Cummins_4x4
    01_Cummins_4x4
    Both bands should be adjusted as they probably have never been done unless the trans has been fully rebuilt.   I just adjusted both bands on my buddy's 48RE, and now it shifts correctly from
Solved by TCMagnum
Go to solution
WT mod should be done in full first. I don’t have much troubleshooting experience with autos as I have the 6 spd but from what I understand a lot of issues are solved when the mod is done. At least you can rule that out.
I don't think you have an AC noise issue, although performing the W-T ground reference mod would be a good idea, if you haven't done that already.  Usually, AC noise affects torque converter lockup stability which is the problem most people have.
When the transmission does an unwanted downshift, does the torque converter lock up, or does it stay unlocked?
What about the code - P0122 Accelerator Position Sensor (APPS)
Signal Voltage Too Low, is it still there?  If it is, I would get that cleared up first.
- John
I don't know if he did the WT mod fully, he rerouted a ground wire that runs with the alternator wire that runs across the front of the engine and behind the alternator and ran it across the top of the front radiator support .
Quick update, after replacing cable ends, cleaning grounds, no change. Replaced the APPS sensor and did the relearn procedure and i cleared the code and so far that P0122 code has not come back and he's driven it everyday, which to me seems a little odd as that code in the manual tends to point towards a wiring short. He also swapped trans relays, and it did better got up to 70 before it started dropping out of O/D.
Would band adjustment have anything to do with this?
Edited by TCMagnum
I just adjusted both bands on my buddy's 48RE, and now it shifts correctly from 2nd to 3rd gear without having the shift delay it was having.
It was rebuilt 10+ years ago
On 2/17/2025 at 1:16 PM, Mopar1973Man said:
What kind of mileage since the rebuild?
I would say no more than 30K...and that's a little generous. It sat for a few years without being driven.
  • Solution
Well I think the old man's truck is fixed...
I had a gut feeling before  tearing into the trans, something less invasive should be attempted first,  after some more reading about the 47re online, and noting some "weird" issues caused by the output speed sensor, we removed the OSS and found this. ,(see picture)
Installed a new speed sensor and he took it for a test drive, got it up to operating temperature and drove 30 miles round trip with NO issues,  and most important,no  random kicking out of overdrive. Which before you couldn't go 5 miles without it happening.:think::thumb1:
Edited by TCMagnum
Add picture
2 trips to town today due to working on another vehicle with 0 shift issues.
I had the same problem on a 2001 I had for a short time OD would drop out randomly. It had a ton of problems. (Full of water) but the OD issue wound up being the APPS. I swapped the unit from my 2000 daily into into it and it drove perfectly.
  • 3 weeks later...
  • 4 weeks later...
Annnnddd we're back..
Last week, lost 3rd and no OD.
Went ahead and replaced the cheap OSS sensor with a mopar sensor, no change.
So after replacing the governor pressure transducer/sensor and solenoid, the truck will go into and hold 3rd gear fine now, but overdrive isn't engaging.. I wasn't thinking but we should've replaced the OD and lockup solenoid while we were in it the first time but...doh....
Anyway, I read that to possibly isolate the issue to mechanical or electrical, to hook a high psi pressure gauge to the Overdrive line pressure test port above the rear cooler line fitting, so we did that today.
Did 6 tests, running up from 1st. Everything goes fine up to 3-4 shift, not even a hint of wanting to go in to overdrive, On 2 of the 4 tests we did see almost 80 psi of pressure and sounded like it tried to go in and then it immediately dropped back down to nothing...
But as for the other 4, never a raise in pressure..and I did verify my gauge was working by testing it on my truck.. and it performed as expected.
But on my dad's, nada.
I also jumped the Brown O/D ground wire to straight to ground and nothing happened.
Now I would think if it were a blown seal or pressure leak in the OD Unit when OD engages, pressure would rise some and then fall..
I could also tell when fluid entered the gauge line.which it only did twice
Any suggestions are appreciated....
