- Replies 21
- Views 3.3k
TCMagnum 9 posts
Mopar1973Man 5 posts
01_Cummins_4x4 2 posts
Tractorman 2 posts
WT mod should be done in full first. I don’t have much troubleshooting experience with autos as I have the 6 spd but from what I understand a lot of issues are solved when the mod is done. At least yo
@TCMagnum, Good job determining that that it is actually downshifting to 3rd gear. I don't think you have an AC noise issue, although performing the W-T ground reference mod would be a goo
Both bands should be adjusted as they probably have never been done unless the trans has been fully rebuilt. I just adjusted both bands on my buddy's 48RE, and now it shifts correctly from
I said i'd have some questions about my dads truck so here goes...
2001 Ram 2500 24 valve, 47RE automatic. Transmission was rebuilt years ago before he had the truck. not sure what all was done to it specifically.
It will randomly kick out of Overdrive sometimes cruising around 55mph, sometimes cruising at 60/65mph. It will kick in and out of overdrive 2 or 3 times in a row and then go back in and hold.
When he first described the problem to me i wasn't sure if it was O/D or Lock up giving an issue.. So i did the first test in the Alternator noise thread about isolating the alternator by removing the field wires and removing the 140 amp fuse in the box, went for a drive and the problem persisted and i was able to see that when it drops out it goes from cruising at around 18-1900 rpm at 55mph to 23-2400rpm at 55mph, so at this point i was certain it was Overdrive dropping out and not TC lockup.
Now my next question is he has a P0122 'A' code for APPS sensor, could this have an affect like that? We've done that APPS reset procedure for the heck of it and it had no change on the problem. I'm not sure if the APPS has any play into transmission shift control or not.
Edited by TCMagnum
