Crankcase oil volumes
So my truck a 2000 5.9 ALWAYS took 11 quarts which would bring it up to the bottom of the top line on the dipstick... Two years ago I had to have a reman long block installed and now 11 quarts makes it look like I'm running a quart over on the dipstick.. Has anyone else noticed a difference, I've seem people arguing on-line about how much oil to fill when doing an oil change so it is possibly a real thing.
Just thoughts that have been bugging me.
  • Replies 6
  • Views 2.3k
    Geno's sells the replacement dipsticks if needed. 2nd Gen Cummins have been 11 quarts for a long time. Its only when you switch to 3rd Gen the 12 quart oil system came to being.
  • Tim Waldo
    Tim Waldo
    all I can say is I have done nothing but give 865Diesel grief over their shoddy work... so I wouldn't doubt I got someone else's dip stick.... SO... I did some research and once again 865Diesel screwe
Yes, 11qts is what the FSM calls for. When you installed the remanufactured long block did it come with its own oil pan and dip stick, or did you reuse the old parts? If the long block came with an oil pan, which it most likely did, and/or dip stick, most likely didn't, then either it is a reduced volume oil pan or an inaccurate dipstick.
honestly I don't know... the installer was over an hour away so I couldn't keep as much of an eye on them as I would have liked.... I PRESUMED it was my original pan.... dipstick seems to be my oringinal... but again who knows.
I wonder ifthe dipstick was traded from another truck by accident and the level is now incorrect. The only other thing I can think off is a ton of sludge in the engine but most likely not true here. At least I hope so.
SO... I did some research and once again 865Diesel screwed me over.... new long block CAME WITH new oil pan and new dipstick...
The length is the same (45") but I"m sure the markings are off... 11 quarts shows at about 5" on the photo...
The dipstick they sent back with the truck is #3935648 GENOS says the correct # for the 2000 5.9 is #3944594
correction... Genos says #3935648 IS the correct replacement and #3944594 is what it replaced.
Edited by Tim Waldo
added a correction.
