SO...after 15 years, my fuel pressure sensor is dying. Called EDGE and they suggested a replacement sensor: 4000700 for $90. Not being able to 100% sure tell me it would work with the Attitude... Any suggestions on this? alternate sensors, alternate fuel pressure/EGT gauges? I am down to only using the Attitude to monitor these two things and would seriously consider changing to a 2 in one guage.... the JUICE module is apparently dead.
  • Replies 17
  • Views 290
  • Tractorman
    Tractorman
    Unless you are absolutely set on having a gauge readout, there is the option of using just using a low pressure warning light. I have used the adjustable LEFOO LF20 pressure switch for years. It is
    ISSPro EV3 gauges give both functions electronic gauge with Bluetooth ability to reprogram any settings in the gauge. Lights (color), warning color lights, set range of warning, much more. Might take
  • Tractorman
    Tractorman
    It is true that the overflow valve is regulated at 14 psi. However, this pressure (and the fuel return flow provided) has no correlation to lift pump pressure. Your statement here is misleading.
Unless you are absolutely set on having a gauge readout, there is the option of using just using a low pressure warning light. I have used the adjustable LEFOO LF20 pressure switch for years. It is my personal choice because the only thing that matters is that there is always positive fuel pressure at the VP44 inlet. The actual pressure value is unimportant. The activation of a LED warning light will catch your eye more readily than a low reading of a fuel pressure gauge.
This particular pressure switch has a range of 0.5-150 psi and comes preset at 10 psi. It is compatible with oils and diesel fuels and it is very easy to adjust to a custom pressure value. The cost is under $40 from a variety of sources, including Amazon. You can easily wire in a LED light at a location of your choice.
  • John
IF I can customize the pressure alert, I would be fine with an alert bulb... I want to know my lift pump drops below 14 psi... I'd still have to have some way to check the pressure when setting it.
Any particular reason you don't want your lift pump to fall below 14 psi?
You could plumb in a tee right at the injection pump fitting just for your test gauge.
  • John
Edited by Tractorman
the over supply valve/over pressure valve or whatever you call it pops off at 14 psi... at 14 psi you get extra fuel flow to cool the pump.... at least that is what I've read and why my new VP44 came with a NEW OPValve... with specific instructions that it HAD to be installed or the pump would not be warrantied.
The fuel pressure below 14 PSI is lower return flow while the engine is running. Basically demand of the engine will take more fuel to the engine and less on the return from the VP44 pump. If fuel pressure is not stable then your demand volume is greater than your supply volume. Return volume is what remains after injection cycle occurs. This why is not suggested to below 14 PSI because the overflow valve is closed by 10 PSI and no return flow occurs.
so my statement albeit in the right intent was technically incorrect?
So would I be safe just knowing my fuel pressure dropped below 10 psi?
Typically my fuel pressure runs between 13 and 16 psi... with a working guage.
ISSPro EV3 gauges give both functions electronic gauge with Bluetooth ability to reprogram any settings in the gauge. Lights (color), warning color lights, set range of warning, much more. Might take a look at those.
Your statement here is misleading. I do agree that the overflow valve will be closed when fuel pressure that the overflow valve senses falls below 14 psi.
However, the fuel pressure that the overflow valve senses is provided from the flow of the VP44's internal fixed displacement vane pump, not the lift pump. Consequently, the volume of return fuel through the overflow valve is the same for a given engine rpm and load whether lift pump pressure is 5 psi or 20 psi.
The VP44's internal fixed displacement vane pump's flow is regulated to well above 100 psi. This is why the 14 psi overflow valve opens immediately when the engine is started. It never closes until the engine is shut off - regardless of lift pump pressure.
Since the lift pump and the VP44's internal fixed displacement vane pump are plumbed in a series circuit, the volume of the the internal vane pump cannot be changed by lift pump pressure. The volume can only be changed by changing engine rpm.
In the past I have posted the results of extensive testing by others (using a flow meter in the fuel return circuit) that clearly supports what I am saying here. This testing was performed in April of 2001 (before any of us even owned our trucks) by a few Turbo Diesel Register members. About three years ago I performed similar tests, as well. The results showed that fuel return flow remained the same, even when the lift pump was turned off and bypassed.
I post this information in hoping to give a better understanding of the relationship between the lift pump, the internal vane pump, and the overflow valve operation in the overall VP44 fuel pump injection operating system.
  • John
Absolutely.
Reading the following may help you feel more at ease:
I have owned my truck since new and it currently has logged 402,000 miles on the odometer.
  • Odometer 66,000 miles August 2004 - First injection pump set a code P0216 ( a death code for the VP44).
  • Odometer 87,000 miles August 2005 - Injection pump replaced with re-manufactured unit under warranty. Lift pump relocated as an in-tank pump application (also covered under warranty).
Just prior to replacing VP44 injection pump, I monitored lift pump pressure because the word back then (similar to what is now) was that if you don't have 14 psi lift pump pressure, you are going to kill the VP44. So, I drove my truck for a week (250 miles) monitoring lift pump pressure. It operated within factory specs flawlessly and maintained 6 psi at wide open throttle at 2500 rpm.
After the replacement of the VP44 injection pump and the replacement / relocation of the lift pump as an in-tank lift pump, my new lift pump pressure was 6 psi at idle and 3 psi at wide open throttle - yes, 6 psi and 3 psi! I was not concerned because by then I had learned much about the true operation of the VP44 fuel system. According to all of the diesel forums, I should have mutilated the VP44. But, that didn't happen..., and it still hasn't happened.
  • Odometer 250,000 miles April 2016 - Install Smarty tuner and set for mild tune.
  • Odometer 251,000 miles April 2016 - Replace in-tank lift pump (not because of failure, but to have more readily serviceable frame mounted used FASS lift (65 gph). Note that the re-manufactured VP44 has logged 164,000 miles with maximum fuel pressure at 6 psi. Should be dead now, right? But, alas, it isn't. FASS lift pump - 12 psi at idle, 6 psi WOT at 2,000 rpm
  • Odometer 303,000 miles December 2018 - Replace original injectors with RV 275's
  • Odometer 402,000 miles - November 2025 - Now have logged 315,000 miles on re-manufacture VP44. Should be dead by now - right? But, again, it isn't.
I would like to note that this truck has never received fuel additives, nor 2-stroke oil to the fuel. Also, I would like to note that this truck has done lots of work covering thousands of miles at 20,000 lbs gross combined weight crossing lots of mountain passes in hot summer conditions.
Hope this helps.
  • John
Edge Performance Products is a PAIN to deal with... would NOT sell me a fuel pressure sensor without going through the whole trouble shooting process a 2nd TIME!!!!!! now I"m curious what is so special about this pressure sensor...
@Tractorman I decided to go with their outrageously priced sensor because BOOST, EGT and Transmission temp were already running on my current configuration... Cost $120 after tax and shipping were added... I"m going to definitely check it out and see WHY I couldn't find a similar product for less...
This is why I installed ISSPro EV2 gauges and properly protected the sensor. Im on the road but there is a article on my fuel pressure sensor setup.
I can't complain, it lasted 15 years... REALLY curious why they are so secretive with the sensor though... Had to jump through multiple hoops to order one.
Because they have a properitary design for the accuracy of fuel pressure readings. Strangely enough ISSPro sensors will work direcdtly with a Quadzilla display. Just shows why the problems of getting the sensor. Even the ISSPro EV2 pyrometer sensor will exchange on the Quadzilla. Just tidbits...
So.. they shipped it GROUND and took 7 days to get to me from Utah??? go figure... The part number is: p500-50-a-e4c and when it was available was a $5 part.... I'm going to go on and use the one I received for $90 +plus shipping and tax ($120).
SO... I give up... I'm ordering @Tractorman 's pressure switch.... I got Edge's pressure sensor installed and it was all over the place... installed a cheap mechanical gauge at the pump and it pegged at 15+psi... so I'm pretty sure it isn't the pump... which is tuned at 13-14 psi (NEVER saw 15 or more out of it). I have picked up a new screen filter (haven't changed in a couple of years) and a new media filter for the OEM fuel filter.. I also did 'LoanATool' from Oreillys and will check the fuel pressure at the pump one last time...
I recommend mounting the pressure switch remotely. Make the connection with an 18" or 24" grease hose (1/8" NPT both ends) in conjunction with a snubber. Use a bulkhead fitting (from Amazon) for the remote location. Make sure there is at least a 90° bend, or make a complete loop with the grease hose. This reduces pressure spikes to the sensor.
A remote location gives you easy access for testing fuel pressure or replacing the pressure switch. The photo below shows my earlier installation before I purchased the LEFOO LF20 pressure switch.
  • John
