24v - Ram 1500 Cummins
Picked up my next project!!! Mint condition inside and out 1999 Ram 1500 single cab shortbed with a v6.
Going to be putting a 24v Cummins in it.
I think Ill be going with an auto for this one, I have tons of NV5600 and NV4500 available around me but for ease of drivability and fun, me thinks auto...
I should be getting my donor truck this coming weekend. 2001 Cummins 2500 single cab 4x4, Ill have the disc brake axles for sale soon if anyone is interested in the area?
I dont know if ill keep all the questions in this section, I might post in the 24v section for some questions if/ when I need too.
Going to be doing lots to this little guy!
Here is a link to what my inspiration is coming from and pretty much what its gonna be/ look like. Minus the color, going metallic white with some bronze wheels most likely.
Looking for sponsors....... 😉Fass Fuel, Quadzillla, DAP injectors and turbo(s), loads of LMC and more! 😉
More to come!!!
Edited by Stanley
  • Replies 16
  • Views 2k
  • Stanley
    Stanley
    Still searching for a transmission core.....! Kinda ridiculous, I figured there would be oodles of these laying around! After I get that then I can start talking to shops about a rebuild. Randy's i
That will be quite the project. Just curious, what are you going to do with the front suspension for the additional engine weight?
  • John
Ill just have those "2500" lowering springs up front.
I guess I forgot to put the link in for the build Im following. Check it out, pretty sweet rig!
1500 Cummins YT video
Something to double check that rubber mat flooring is typical for rotting out the floors. You might lift the rubber and double-check the interior metal for any rust. One of the common conversions I have to do was pulling up all the rubber mat flooring and fix all the rusted floor metal and then convert to carpet. I've done this in a few rigs that people had rubber floors. Typically the drivers floor pan is rotting.
Yes indeed, carpet is on the "to get list"
The list of stuff to do and get is quite long but the plan is coming together nicely!
@Mopar1973Man is there anyway/option to add a poll to this or should I just make a quick new thread for a poll(s)?
I'm still curious to think what everyone thinks on keep the NV5600 or trying to find someone to buy a full manual swap so I can afford to buy a nice 47RE...
I guess thats another question, do I have to stick with the 47RE in auto? Prolly for simplicity's sake for oem brackets and bolt-n-go scenario Id stay 47RE in my thought process.
If anyone is to ask for the trucks purpose, this will literally only be a grocery getter, play toy, go fast wanna be show truck.
If I swap id have to send in my computers for flashing to auto and the only issue would be to hopefully sell a full NV5600 swap with t-case ready to roll which is the biggest kicker and would halt finishing everything till it sold...
  • 3 weeks later...
Little update:
I had the NV5600 on FB marketplace and really thought I was going to have a hard time selling it, or a lengthy wait. But outta the blue a guy from Wisconsin messaged me and long story short I had 2 hours to pull the trans, t-case, driveshaft, clutch, because he wanted and was gonna walk if I couldn't do it. Walk in the park for me usually, but being broken now different story...
So for 6k, I hobbled my broke but out to the shop and took it out in 1.5 hours. Oh man I was hurting last night! But its sold and now I can put some money together and start seriously thinking about what trans to put in this truck.
47RE is obviously prolly the best choice but, I think I've seen people use the 68RFE I think its called. To my knowledge that's a 6 spd?? Worth Discussing that option or not??
  • 4 weeks later...
Well I got another truck that I just had to have. Another unicorn!!! No rust 79k miles squeaky clean truck. Its a 2001 Dodge 1500 2wd with the V6. This truck is the new 1500 Cummins! The 2001 has update 2 piston calipers up front compared to the older ones only having one. Also the front spindles has unit bearings, easy to replace, stronger, better, etc. One other thing to mention is servicing the brakes are way easier. Having the unit bearings instead of the old style makes it where I can run my newer 3rd gen style rims that I picked up with out needing a 2 inch spacer. There's not many rims that the 99 and older ones can run, actually a pretty limiting factor for other 2nd gen enthusiast.
Heres the new rig!!!
*note: some photos wont upload, I'm getting a error code (-200)??
Immaculate underneath!
They both got a pressure wash bath, super clean!
Edited by Stanley
  • 4 weeks later...
Still searching for a transmission core.....! mad@computer
After I get that then I can start talking to shops about a rebuild. Randy's is looking pretty good, maybe sun coast, still UNSURE on what to go with either of those is around $8500 for 600-650hp.
(Randy's- 2 Year Warranty) (Suncoast- 3 Year Warranty)
Randy's seems to be more dialed/personal in asking very specific questions on the truck to really dial in the trans,
I really need to dial in what size injectors and turbo to run. That 64/71/14 is coming out of there, and prolly for sale!
I currently have DAP injectors = 7x11 sac, and a set of 6x13 sac injectors.
I might need to trade those out or sell them for a different size depending on turbo.
Goal is 600-650 fast fun play toy in a half ton, no towing etc, just a fun occasional DD play toy.
Maybe @dieselautopower has good setup in mind.
I don't know if yall remember my fiasco with the (current-old setup) that 64/71/14 and these big injectors makes some heat. Had a lot of trouble even getting close to decent egts, also had a ton of trouble tuning it.
It used to have a Dragonflow VP and 6x18's and .093 lines and tubes with this turbo.
Once its done, or close to it, hopefully @Mopar1973Man travels will be close to the Missouri line to hang out and do some tuning. Its looking like the fall or next spring itll be finished, of course that depend on how crazy I get with new paint, frame paint, etc. Plan is a frame off build but it might change cause this 01- 1500 is friggin clean/mint!
When I get some time im going to build a tune article and get out of building tunes. Currently life is crazy and been down in Boise for nearly a week. Week before I was staying in Lewiston ID 3 nights looking at my next diesel. Now get home and get the financial stuff done and get my new diesel delivered to the property.
What else will I need to get to run a auto instead of a manual with everything. Brackets? Cables? Wiring? ETC...
Computer flash most likely, as I understand it....
  • 3 weeks later...
It has started! woothyper
I have removed the cummins engine out of my sig* truck, now working on the harness and interior stuff.
Gonna go ahead and make a dedicated engine stand bracket to attach to the engine block then to the new Daytona engine stand I got.
Interior is out now... If anyone needs special pics or curious whats behind the dash- hit me up...
Wiring is coming out slowly. Still not exactly sure if every single harness will need swapped or if I'll just do it all to avoid confusion down the road.
Might rebuild the hvac box again, found that Genos Garage has a ac/heater box seal kit for $55 I might try instead of just making my own with peel and stick foam tape-pita....
Found a 2003 1/2 ton disc brake axle for $300 I might get to change the rear over to disc's. You only have to move the spring perches in just a bit apparently, well see lol.
Its coming along! Wish me luck!
**Still needing insight on what else I'll need swapping over to auto from manual... surely wiring and more?
Wiring anyone???
Entire truck wiring harness...truck
With all this apart I now need to figure out how to make my SLT trim harness work with the base model harness. This will be very tricky. The base model does not have abs* my wiring/modules do, the base model doesn't have power windows, locks, heat and I want them - my harness has them, overhead console/light, etc...
I 'm thinking the only real hold up on just completely swapping harness's is the brake's. There is a brake module in the 1/2, has 2 plugs going to it and its not the same as what the 02 diesel had, obviously. So if I swap everything I'll just be left with a brake problem and now ill have a constant abs light in dash. I'm just now thinking of the speedo, maybe it's the same? Ill have to change info in the trucks computer so it doesn't think there's still 4.10s in the rear etc. Man this seems complicated now haha, am I overthinking this, how much computer stuff will I actually need to change overall.....thud
I got some thinking and figuring out to do. If anyone has pointers or some advice I'm all ears!
